sony bravia xbr-43x830c
  • Martin0101
    • Feb 2018
    • 21
    I have this tv that is complete dead.. it shows no power at all. No stanby light.. i checked the power supply voltages with the harness connected to the main board and here are the only voltages i get... need help to find out the problem..
    Bl-err 2.38v
    Stby 3.47v
    Ac-off-det 3.47v
    • 12075
    • U.S.
    Re: sony bravia xbr-43x830c
    martin0101, do you have good soldering skills, if not I'd just grab that 28 dollar powersupply board from ebay, I know the ebay stuff could be bad but I've had pretty good luck with it. If you want to try to fix the one you have, we can try.
      • 12075
      • U.S.
      Bl-err 2.38v
      Stby 3.47v
      Ac-off-det 3.47v
      THe stby is ok but it looks like youre missing some voltages.
        • 12075
        • U.S.
        Did you check for capacitors bulging at the top, they don't have to bulge to be bad but if they are bulging theyre bad for sure.
          • 12075
          • U.S.
          http://www.shopjimmy.com/sony-1-474-...pply-board.htm good pic.
            • 12075
            • U.S.
            Bl-err 2.38v
            Stby 3.47v
            Ac-off-det 3.47v
            Can you find the schematics for that board?
            • Martin0101
              • Feb 2018
              • 21
              Nomoresonys. I will be buying the one from ebay.. i will keep you posted to see if replacing the power board is the issue.. yea i dounloaded the schematics
                • 12075
                • U.S.
                Cool, I'll subscribe to this thread and check back good luck.
                • will62
                  • Dec 2016
                  • 229
                  • usa
                  You may want to check a little further before buying a new power supply. This set has a self diagnostic function. When the uC detects a problem, an LED flash code is produced. You said that you had no LED status light. If you have standby voltage, but don't have a status light, it could be a main board problem.
                  Your BL_ERR is also slightly above the 1.9V cut-off, so you may have multiple problems. There are ways to force the power supply on, so that you can see if you have a board problem, or a backlight LED problem. That would require some resistors.
                    • 12075
                    • U.S.
                    That is a good plan, I just didn't know how long the board would be available at that price, could do that testing to be sure, board will take at least a couple days to arrive, nice to have a spare tho.
                    • Martin0101
                      • Feb 2018
                      • 21
                      I will try to replace the main boars first..
                      • Martin0101
                        • Feb 2018
                        • 21
                        I checked the backlight with a backlight led tester and they all turn on .. voltage for all of them was 77.6.
                        I dont have any voltage eather when the backlight conbector is plug in to the power supply board
                        • will62
                          • Dec 2016
                          • 229
                          • usa
                          If you're in a hurry, go ahead and order the main board. If not, we could do a little troubleshooting to make sure it's not something simple like a power regulator. Let us know.
                          Keep in mind, even what I'd call an "easy" fix would likely require removing and soldering small smd components. You'd have to be set up to do that.
                          • Martin0101
                            • Feb 2018
                            • 21
                            Will62... i would like to do the troubleshooting. Can you please let me know what i have to do to find out what is the problem
                            • will62
                              • Dec 2016
                              • 229
                              • usa
                              The service manual that I found does not have a schematic, but does have a component location diagram for the main board. The problem is, when you zoom in to see a component, the resolution is crap (see 1st pic). This is going to make it harder than expected to troubleshoot, but we can try. Did you happen to find a better schematic or diagram?
                              You can start by checking all the fuses on the main board. They appear to be well marked, and the color of the fuse (light blue/green?) stands out. There are several on the board, so just take your time and locate all of them. Power off, resistance check, ~0 ohms across fuse.
                              As you are looking for the fuses, keep your eye out for the IC's listed below. Need to see if you can use magnification to read the part numbers on them.
                              IC9003, 9008, 9017, 9018 (almost covered by heat sink), 9401.
                              • PopsCaps
                                Sony Bravia KDL-40V2500 that will not power on
                                by PopsCaps
                                I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                I do not hear any sound and I cannot see any backlight.
                                I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                03-25-2025, 11:23 AM
                              • justin35
                                Sony bravia kdl-43w755c - boot loop
                                by justin35
                                i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                from what i read online it looks to be an emmc issue…
                                i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                i took out the board and say an samsung 16gb emmc
                                i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                i could try to put one instead of the 16gb one, but will it work?
                                where do i get the software from?
                                any help will be much appreciated!...
                                03-06-2024, 12:26 PM
                                Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                                Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                                10-16-2024, 05:15 AM
                              • Spc.
                                Sony Bravia KD43XF7596BAEP - Android no picture
                                by Spc.
                                Greetings everyone.
                                I also have Sony Bravia, model:
                                Sony Bravia KD43XF7596BAEP - Android.
                                What happend is that image dissapeared while we were watching tv.
                                Diagnostics:
                                1. TV turns on, no errors
                                2. Backlight turs on, no errors
                                3. Power indicator turns on, white color, no errors
                                4. Menu works on android, you can hear sound while switching channels
                                5. Volume up and down works via TV remote and via buttons
                                6. Tunner works, HEVC / MPEG-4 decoder works
                                7. I get audio from channels
                                8. No picture is present,...
                                05-19-2022, 04:28 AM
                              • KYBOSH
                                Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                                by KYBOSH
                                Previous owner said TV just went blank one day.
                                They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                                Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                                The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                                There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                                I just downloaded the Sony KD-75X7800F Service Manual and...
                                11-19-2024, 10:12 AM
