Need help with Samsung LN40E550f7f
  • Kindred1
    • Feb 2018
    • 55
    Re: Need help with Samsung LN40E550f7f
    Originally posted by budm
    Is the ON = 169.2V reading with PS-ON present? If PS-ON present then we have problem with the PFC circuit. But I thought you have 365V on the fuse next to the filter cap before in the earlier thread, that must have been an error then.
    O.K. What I have is : 164.5 vdc with power on. 168.3 vdc on standby.
    361 vac with power on, 370 vac on standby.
      The readings in AC mode are just error of you meter.
      Try measuring your car battery in AC Volt mode to see what you get, it will show high reading. Your meter probably has simple half-wave rectifier in the AC input circuit of the meter feeding resistor networks for the meter scale.
      Any way, you will need to fix the PFC circuit at this point.
      Real AC Voltage of over 300VAC on that electrolytics cap would have blown the cap by now.
      https://www.badcaps.net/forum/attach...6&d=1519521712
      Check the RESISTANCE of the PFC diodes in both directions to see how many Ohms they will show.
      • Kindred1
        • Feb 2018
        • 55
        Try measuring your car battery in AC mode to see what you get.
        Yes. Hence my comment to you regarding me misunderstanding and screwing up. Apparently headaches/neckaches effect brain function. Anyway, I will do that first thing tomorrow and post my results. Thanks!
          At this point it is safe to say that you do have problem in that power supply/inverter driver board, you have all the correct command Voltages and other low switched Voltages but do not have the boosted Voltage to run the inverter driver circuits, we are getting there.
            • 12088
            • U.S.
            #125
            http://en-us.fluke.com/training/trai...ultimeter.html I believe you said your meter wasnt working in diode mode, this shows how to check diode in ohm mode, if you get ol in both directions try setting meter at 2000 ohm, often you get inaccurate measurement results when left in circuit. Diode should read ol in one direction, reverse meter leads and should get a reading.
            • Kindred1
              • Feb 2018
              • 55
              Ok guys. I got my meter working properly. SO, in diode mode DP810 and DP802 both read .6v in diode mode - OL in reverse as it should I believe. However in Ohm mode I get OL both directions no matter what setting it's at. I have tested other circuits to verify ohm mode is working.
                OK, then we need to look deeper in the PFC circuit section, need to get the P/N of the PFC Controller IC so we can look up the spec sheet to locate the VCC pin to see if it is getting the switched VCC for the PFC IC to run or not.
                PFC IC has designator as ICP801.
                Repair kit:http://www.shopjimmy.com/samsung-bn4...repair-kit.htm
                • Kindred1
                  • Feb 2018
                  • 55
                  Ok, I found it. - It appears to have a little corrosion/heat damage on the top. ( no scorching on or around.) All I can make out is as follows.
                  B7E
                  AN
                  7930B
                    • 12088
                    • U.S.
                    #129
                    Sometimes you will get an error reading when testing in circuit.
                      FAN7930B
                      https://cdn.badcaps-static.com/pdfs/...0db2152410.pdf
                      Pin 8 is VCC, Pin 6 is GND which is connected to circuit GND (negative leg of the main filter cap) of the hot side, so be real careful since you are making measurement in the HOT DEADLY side of the circuit; I suggest you to at the least plug the TV into the GFCI outlet to protect yourself.
                        • 12088
                        • U.S.
                        #131
                        https://www.digikey.com/products/en?...G&pkeyword=&v=
                        Is this it?
                        • Kindred1
                          • Feb 2018
                          • 55
                          FAN7930B
                          I get 34.7vac
                          • Kindred1
                            • Feb 2018
                            • 55
                            My antivirus blocks that page.
                              • 12088
                              • U.S.
                              #134
                              lol, thats digikey theyre known worlwide, definitely not a nefarious site.
                              • Kindred1
                                • Feb 2018
                                • 55
                                I think it's just their certificate. Heading there now.
                                • Kindred1
                                  • Feb 2018
                                  • 55
                                  the 4th one is.
                                    • 12088
                                    • U.S.
                                    #137
                                    You could exclude them in your antivirus, as in white list, lets the antivirus know that this site is ok.
                                      • 12088
                                      • U.S.
                                      #138
                                      the 4th one is.
                                      Ok, make sure, I think digikey has more reasonable shipping costs than mouser.
                                        • 12088
                                        • U.S.
                                        #139
                                        Will 5 or 6 work, not sure but I think 4 says minimum purchase is 2500, you could call and ask tho.
                                        • Kindred1
                                          • Feb 2018
                                          • 55
                                          All the specs seem the same except for the packaging type. I don't know anything about said components except what I'm learning.
                                          • Nicktronic
                                            Samsung Power Supply Board BN44-00874F
                                            by Nicktronic
                                            Hey everyone,
                                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                            Anybody...
                                            03-17-2025, 06:20 AM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            by ohren
                                            09-08-2023, 05:24 PM
