Need help with Samsung LN40E550f7f
    • 12086
    • U.S.
    #41
    Re: Need help with Samsung LN40E550f7f
    So after you do the jumper procedure check for your blu-on voltage, if it is still missing, the problem is on the power supply board.
    • Kindred1
      • Feb 2018
      • 55
      https://www.youtube.com/watch?v=n54IurMvr6o here's a video explaining the jumper procedure.
      ok, so do I jump BLU_ON with b5v and ps_on with A5v?
        • 12086
        • U.S.
        #43
        Connector off mainboard jumper standby and blu-on backlights should come on and stay on.
          • 12086
          • U.S.
          #44
          Try blu-on on with 5v, if that don't turn on backlight you may need to connect ps on blu on and 5v together.
          • Kindred1
            • Feb 2018
            • 55
            Ok. Which one is standby?
              • 12086
              • U.S.
              #46
              the one with 5 v
              • Kindred1
                • Feb 2018
                • 55
                There are 2. A5v and B5v
                  • 12086
                  • U.S.
                  #48
                  Check video in post 40.
                    • 12086
                    • U.S.
                    #49
                    Ok looked at your board again try A5 and blu-on.
                    • Kindred1
                      • Feb 2018
                      • 55
                      That is a little different, I think you can use either one.
                      Actually, I was wrong, there are 3. p_dim, A5v and b5v.
                        • 12086
                        • U.S.
                        #51
                        You know what? I'm not sure about this particular board, might have to wait for one of the pros to lend a hand, sorry. I'm just not sure, no sense risking messing something up.
                          • 12086
                          • U.S.
                          #52
                          disregard.
                          • Kindred1
                            • Feb 2018
                            • 55
                            On mine it says like 3.3 or 5 v for blu on but I noticed your blu_on voltage is 13v so better not jumper those, I'm not sure what will happen.
                            I think you may have misread. BLU_ON is 0v
                              • 12086
                              • U.S.
                              #54
                              That shopjimmy video in post 40, he is working on a samsung but I don't know if it has all the same workings as yours.
                                • 12086
                                • U.S.
                                #55
                                I missread.
                                  • 12086
                                  • U.S.
                                  #56
                                  http://www.shopjimmy.com/samsung-bn4...upply-unit.htm if you click the image it will magnify.
                                    • 12086
                                    • U.S.
                                    #57
                                    Oh crap, my bad I was looking at row1, you can go ahead blu-on is'nt 13 v, it's the row 1 that has the 13.
                                      • 12086
                                      • U.S.
                                      #58
                                      Go ahead and jumper A5 and blu-on. Just make sure you get the right row by tracing it down your connector.
                                      • Kindred1
                                        • Feb 2018
                                        • 55
                                        Jumped it. No backlight.
                                          Can I see the picture to show how you jump the pins of BL-ON (pin 6) and the A5V (pin 12)?
                                          Did you us resistor or you use jumper wire?
                                          I always use resistor in case the mistake is made by jumping the wrong pins together.
                                          • Nicktronic
                                            Samsung Power Supply Board BN44-00874F
                                            by Nicktronic
                                            Hey everyone,
                                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                            Anybody...
                                            03-17-2025, 06:20 AM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            by ohren
                                            09-08-2023, 05:24 PM
