TNPA 5330 Q621, Q622, Q623 issue
  • gldiana
    • Sep 2017
    • 16
    • Italy
    Hallo all!
    I have a problem with a tnpa5330: checked all, changed all blown Qs and Ds, but on power on still 6 blinks and Q621, Q622, Q623 blow up. Already blown 9 of them. Checked opto and driver IC and they seem ok. Q661 not shorted. I have finished my options...
    Any Ideas??
    Thank you!
  • tw2005
    • Oct 2011
    • 6458
    Re: TNPA 5330 Q621, Q622, Q623 issue
    Chinese IGBT fakes?
    • gldiana
      • Sep 2017
      • 16
      • Italy
      No...Original 30F131 and good fgd4396, all blown on power on...And same result removing driver IC Q762...
      • chrismurphy
        • May 2014
        • 251
        • australia
        Originally posted by tw2005
        Chinese IGBT fakes?
        I don't believe Chinese would waste their time on producing fakes
        Never had any issues with semiconductors from china
        • chrismurphy
          • May 2014
          • 251
          • australia
          When you replace the mosfets check the gate resistors as if one is open circuit or damaged it will take out the lot
          • gldiana
            • Sep 2017
            • 16
            • Italy
            Thanks for suggestions. Res checked and all ok. I was thinking to remove IGBTs and check vemitter-collector voltage: do you think that it could damge something else?
            • tw2005
              • Oct 2011
              • 6458
              Maybe not manufacture but they have no problem in sanding the casing and restamping them so essentially not what they present them to be. I had a good run for a while.
              • chrismurphy
                • May 2014
                • 251
                • australia
                Maybe not manufacture but they have no problem in sanding the casing and re stamping them so essentially not what they present them to be. I had a good run for a while.
                I dont want to start an argument but sanding and re stamping i dont think so no money in it for the price they sell at
                Sand what off and re stamp with what 60N120 changed to 65N100 or what ever
                I have heard this so many times but i think its a urban legend
                I will let it be
                Anyway to the OP you realy need to check as many components as you can .
                I have been lucky with most boards but with panasonic not ever , they always blow
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  I can send you a selection of fake parts for you to lnstall. Check them first,ignore the readings, and use them. You will chnge your tune for sure.
                  • chrismurphy
                    • May 2014
                    • 251
                    • australia
                    ok send to 25 dominic crescent morphett vale SA 5162
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      Better yet, pay for them yourself and feel the total anger rush. Then try to contact the bastards for a refund and they ask if you know how to test them.
                      • chrismurphy
                        • May 2014
                        • 251
                        • australia
                        You said you would send some ,anyway i have repaired other boards with fets from china and never had any issues. I will let this be ok
                        • tw2005
                          • Oct 2011
                          • 6458
                          Originally posted by gldiana
                          Hallo all!
                          Any Ideas??
                          Thank you!
                          See if this blog reveals anything, sounds like he had similar issues plus additional parts replaced to get it running.
                          http://alpengeist-tvrepair.blogspot....330-board.html
                          • gldiana
                            • Sep 2017
                            • 16
                            • Italy
                            [SOLVED] Thank you all for all suggestions. This problem has been soved changing IC921: now those Qs do not blow.
                            But now I have still 6 blinks.. Checked Q441, Q451, plus all resistors and caps, plus all driver ICs...But I read zero volt across C916... Any ideas???
                              Acer ConceptD CN316-73G-5330 Notebook 3 Specification for Upgrade or Repair
                              This specification for the Acer ConceptD CN316-73G-5330 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the CN316-73G-5330 boardview and CN316-73G-5330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-07-2024, 03:40 AM
                            • Userrrname
                              Tx-pr42gt30 6 blink
                              by Userrrname
                              👋🏻I recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...
                              07-19-2025, 07:53 AM
                            • mmccomputer
                              Dell Latitude 5330
                              by mmccomputer
                              Hello everybody
                              I have a dell latitude 5330 which does not turn on (except the power button and the keyboard backlighting for a second, no fan ..), I have the primary voltages 3.3v and 5v, the 13v from the battery, no processor voltage and no gfx voltage, and I have the 1.8v present I don't know what it is for (maybe the ram), if anyone has an idea what it could be?
                              nb: I flashed the bios and it's the same result
                              Dell Latitude 5330
                              Intel core i5 -12th gen
                              MB: VJMWH$LA 223014-1 SOUTHPEAK 13 MLK MB
                              super IO: Mec 5200-LJ​
                              11-25-2023, 02:32 AM
                              Dell Latitude 5330 Laptop Schematic
                              ADL-P 203101...
                              10-08-2024, 07:37 AM
                            • eenee
                              Inspiron 5330 BIOS needed
                              by eenee
                              The laptop turns on but no image.
                              ST: 1KRPLS3
                              Motherboard number is Odin n13 mlk rpl 10l mb 213238-1...
                              08-19-2024, 11:21 PM
