DVD player stuck in 'startup'?
  • notallbad
    • Oct 2012
    • 1190
    DVD player from power up stays in 'startup' mode, green led lights up but nothing else happens. Sometimes the DVD tray will eject on power up but no other response from remote or front panel. The VFD panel does not light up either.
    Please can someone help!
    Thanks in advance.
  • R_J
    • 9628
    Re: DVD player stuck in 'startup'?
    No make, No model, No pictures = No help
    • notallbad
      • Oct 2012
      • 1190
      yeah, having trouble uploading at the moment.
      bear with me.
      • R_J
        • 9628
        Are those connections poorly soldered on ic105 in the power supply section? resolder them and that should fix it.
        • notallbad
          • Oct 2012
          • 1190
          Re-flowed the solder joints but sadly no change.
          • R_J
            • 9628
            The connections looked to be bad, were they? What is that ic? looks like it is the 9 volt line. maybe the bad connections caused it to fail, also if they were that bad there may be other similar parts with bad connections.
            On P9501 pin 15 looks like it is unsoldered? or is the pin just missing? same goes for P6401 pin 17
            Can you check fuse F103 (near secondary of transformer)
            • notallbad
              • Oct 2012
              • 1190
              IC105 - KA78R08 low dropout volt reg, they were ok I think but reflowed anyway.
              P9501 & P6401 pins are both present and have been reflowed anyway but no change.
              Fusible link F103 tests ok.
              • R_J
                • 9628
                Are all the voltages present from the power supply? You should also be able to measure the filament votage on the display, it is the outer pins marked F, on each side of the display, there should be about 3-5 volts a/c across them
                • notallbad
                  • Oct 2012
                  • 1190
                  P6401
                  pin 5 - 12VA reads 10.8v
                  pin 20 - 5v A reads 4.97v
                  pin 21 - 5v A reads 4.97v
                  pin 25 - 12v reads 10.92v (voltage only present with controller board connected)
                  pin 27 - 4.2v reads 4.97v
                  P9501
                  pin 5 - 5VD reads 4.97v
                  pin 6 - 5VD reads 4.97v
                  pin 11 - 3.3VM reads 3.12v
                  pin 12 - 3.3VM reads 3.12v
                  pin 13 - 3V reads 3.14v
                  pin 15 - 2.5V reads 2.75v
                  pin 17 - 8V reads 7.6v
                  pin 18 - 8V reads 7.6v
                  pin 23 - PWR CTL reads 4.64v
                  pin 28 - M RESET reads 4.76v
                  pin 29 - MODE SW reads 4.72v
                  • notallbad
                    • Oct 2012
                    • 1190
                    What points to I measure across to get that reading, should there also be a D.C volt on there too?
                    directly across F+ and F- reads 7.2v ac
                    gnd to F+ gives 20.3v dc
                    gnd to F- gives 23.9v dc
                    • R_J
                      • 9628
                      Those voltages seem to be ok on the display, it gets driven by the microprocessor.
                      I could not find a schematic on this dvd, If you can look up the microprocessor number, make sure it has the correct voltage to it, check the power on button and check the line back to the micro to make sure the comand is getting to it. there is a small ic near the micro. labled ic902, whats the number on it, It could be the micro's reset ic.
                      • notallbad
                        • Oct 2012
                        • 1190
                        IC902 - KIA70420AP Volt detector
                        The nearest SM I could find is attached, not exact but very close.
                        The power on button removed checks out ok. Also reads 4.8v between pins 1 & 2 of P9902, drops to 0v when power button pressed.
                        • R_J
                          • 9628
                          Check the voltage on that reset ic in case it is holding the micro in reset.
                          the voltages seem to be all there which seems to mean the power control line is turned on, I would think if the unit was in standby that line should be low coming from the micro
                          • notallbad
                            • Oct 2012
                            • 1190
                            There are no markings on IC901, P9902 Pin 2- PowerKey goes to P9904 Pin 1 - KeyIn1 and to Pin 23 on IC901.
                            IC902 reads Pin 1 - 4.85v and Pin 3 - 4.84v.
                            • R_J
                              • 9628
                              On those regulator ic's ic105, ic106 & ic107, Pin 1 is used to turn them on and off, It would seem they are turned on, that control comes from the microprocessor, so something does'nt seem right with it.
                              If you monitor the pin 3 of ic902, with power pluged in, then unplug for 1/2 sec and plug back in does that voltage go to 0 then back to 4,8 ?
                              • notallbad
                                • Oct 2012
                                • 1190
                                IC902 Pin 1 goes to IC901 Pins 24 & 25
                                IC902 Pin 3 goes to IC901 Pin 6
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Needs to be switched off for 1-2 secs before Pin 3 drops out to 0v and then recover to 4.8v.
                                  Power off for 0-1sec the voltage remains steady at 4.8v.
                                  • R_J
                                    • 9628
                                    ic 902 is the reset ic for the microprocessor. it needs to see a reset pulse after the unit is pluged in. that tells the microprocessor to start its code from the begining.
                                    I guess the reset pulse is most likely ok.
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      This was done with the Controller board and dvd tray disconnected!
                                      With the Controller board and dvd tray connected IC902 Pin 3 drops out when power removed for 0-1secs.
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        On closer inspection I.C901 uController is a PD780232.
                                        RESET pin is 'notted' (active low) so see the point to I.C902 KIA0742P.
                                        Would I be correct in assuming that if IC901 is 'dead', or corrupted ROM this unit has effectively had it? It would seem the ROM is programmed at factory so who knows what the address code/operations would be.
                                        Though not quite given up yet! It has occurred to me that the crystal could be at fault, is that possible considering the unit could well have been moved about alot with undue care. How could I check that?
                                        What else could cause the ucontroller to behave unresponsive, all voltages appear correct coming from the power supply and around the boards.
                                        I would expect at the very least that the VFD would come on if the problem was with the Main Controller board or the DVD Tray laser etc...
                                        • bogosort
                                          Sony DVD player stuck tray (DVP-SR310P)
                                          by bogosort
                                          I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                                          Anyone knows why?
                                          Thank you....
                                          05-11-2024, 04:29 PM
                                        • nervous_capybara
                                          Repairing the Hitachi DA-6000 CD player
                                          by nervous_capybara
                                          Hello everyone !
                                          I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
                                          Feel free to share your experience if you ran into other issues.
                                          DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
                                          CD tray would not come out of the player
                                          I could hear a motor spinning inside the player but the CD tray would not come out.
                                          Turned out that the issue was the CD tray belt that aged poorly and began to...
                                          11-05-2025, 03:11 AM
                                        • BMCappelletti
                                          Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                                          by BMCappelletti
                                          Hi everyone.
                                          Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                                          Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                                          Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                                          02-18-2025, 12:22 PM
                                        • Stunt
                                          Hp Laptop Stuck on Hp protected by hp sure start screen
                                          by Stunt
                                          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                          screen that's it and stuck there. I left it until the following day and i still...
                                          09-02-2025, 01:51 PM
                                          MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 05:30 PM
