2015 Insignia NS-55D421NA16 No Standby-PSU Sparks
  • Acesales
    • Jun 2017
    • 58
    Hello all, I'm back again with some questions. I have been able to get through a couple previous projects alone, thanks to you folks. I acquired a 55" Insignia NS-55D42NA16 LED TV, built 11-2015. No standby light, I get 168VDC across the filter caps and can chase it through the hot side till I get to the transformer SYEQ2612-T012A. A 4R7 4.7uH inductor snapped and sparked on the board without my help. I did not have any probes on the board at the time. It is LD1 and located between the AV5 RCA inputs. I can see no burnt or damaged areas. Subsequently, when viewing with a FLIR camera that inductor is "pulsing" every second or two and momentarily heats to about 105 deg F. Seems it is going into overcurrent protection? What should the voltage be on the secondary side of the Xfmr? Thanks
    Re: 2015 Insignia NS-55D421NA16 No Standby-PSU Sparks
    Can we see the pictures of the whole back side of the TV showing how ALL the boards are connected together?
    • Acesales
      • Jun 2017
      • 58
      I removed the bottom speaker enclosure and found this. I have not removed the metal back- it appears the only wire going into the panel enclosure is the LED lighting cable. This is the newest and the lightest model I have worked on- compacted for sure.
      • Acesales
        • Jun 2017
        • 58
        I believe I found a schematic.
        • Acesales
          • Jun 2017
          • 58
          Now this step down converter M3406-ADJ self destructed on it's own. Any ideas?
          • Acesales
            • Jun 2017
            • 58
            I believe this is the circuit for the burned step down converter.
            • R_J
              • 9588
              You could have a shorted component on the 1.15 volt line that caused the regulator to fail. It is likely that was the part that sparked originally and not the coil.
                I would remove that burnt IC then check the RESISTANCE between GND and the output where the filter caps are, I.E. CD3~4, to see if it will show very very low resistance or not.
                • Acesales
                  • Jun 2017
                  • 58
                  Test to ground;
                  RUN= infinite
                  FB= 59 ohms
                  SW= 5.4K
                  • Acesales
                    • Jun 2017
                    • 58
                    The maximum allowable voltage in for the M3406 step down converter is 6.5V. I am measuring 12V after removing the burnt chip. Is it high because there is no load?
                      I expect the input pin to be fed from either 5VSTBY or switched 5V.
                      You may want to trace the input pin to see if it is connected to the 12V power source some how.
                      • Acesales
                        • Jun 2017
                        • 58
                        Budm, I misidentified the circuit in question. The problem circuit is actually the 5V STB supply circuit. My schematic is wrong in regards to part ID's. So the MP1470GJ-Z actually burnt. I saw 5 pins, I wonder if the initial spark was a pin burning off.
                        • Acesales
                          • Jun 2017
                          • 58
                          Pin 1 (GND) is supposed to be ground but I have an inifinite reading to several ground points.....chassis screws?
                          Pin 2 (SW) is shorted to ground. You guys were right.
                          Pin 3 (IN) 5.45K to ground and 0 volts.
                          Pin 4 (FB) trace is damaged.
                          Pin 5 (EN) shows 12VDC.
                          Pin 6 (BST) reads 59.5 ohms to ground.
                          • Acesales
                            • Jun 2017
                            • 58
                            More random unidentified circuits. The schematic I found for this TV is not great but the manual is for a Hisense, not Insignia, but very close.
                            • R_J
                              • 9588
                              Does pin 1 of the ic have continuity to the ground pin on that "pwr upgade" plug? it could be that the ground is isolated from the chassis
                                So with that IC removed and you check the empty pad of pin 2 and GND, does it show very low resistance still?
                                So the always on 12V is feeding this buck converter circuit to produce the always on 5VSTB.
                                If you do not see any shorted at the SW pad of that IC's then you may be able to use external 5V supply to feed that 5VSTB point and see if the TV will work normally or not, I would prefer to use power supply with DC current meter built in so you can see if the circuit is drawing excessive current or not, we also know that the IC is rated 2A so you know what the maximum the current draw by the circuit should be.
                                BTW, do you have the whole schematic or the whole service manual that you can upload for us?
                                • Acesales
                                  • Jun 2017
                                  • 58
                                  Here is the service manual I found. I couldn't read the part number on the burnt IC. I'm wondering if my PSU requires a different part number than what is listed in the schematic.
                                  JR, there is no continuity to the "power upgrade" connector. I can chase pin 1 through a >1 ohm resistor and a capacitor.
                                  budm, yes, shorted between pin 2 and ground, unless pin 2 is ground and I am chasing the wrong converter part number.
                                    If you follow pin 2, see if it is connected to an inductor or not.
                                    Can you please provide straight shot of that section?
                                    https://www.badcaps.net/forum/attach...7&d=1519095492
                                    • Acesales
                                      • Jun 2017
                                      • 58
                                      Here are the close ups.
                                        https://www.badcaps.net/forum/attach...4&d=1519428544
                                        Pin 2 (to the right of the pin 1 that has triangle marking) looks to be connected to the 12V pin of the connector, can you check on that?
                                        • daltonjr.
                                          Searching for Macbook M1 M2 0.47UH 1.7A 0.175OHM inductor
                                          by daltonjr.
                                          I dont have newer doner boards for M1,M2... machines and I see these inductors often blow with water damage.
                                          Anyone know where I can buy a few 0.47UH 1.7A 0.175OHM inductors, I did not find it.
                                          Thanks!...
                                          02-21-2025, 12:02 PM
                                        • Bartoloni
                                          Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                                          by Bartoloni
                                          Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                                          everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                                          there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                                          replaced the capacitor (330) and the inductor (R15) without any change
                                          any idea? very thank you!
                                          input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                                          12-09-2024, 12:42 PM
                                        • badcap111
                                          How to read inductor specs?
                                          by badcap111
                                          I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
                                          INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
                                          I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
                                          09-12-2023, 01:25 PM
                                        • silver60618
                                          Blown Inductor on WD My Passport
                                          by silver60618
                                          Hi Guys, my WD My Passport drive powers on, then powers off. Ive taken out the motherboard and identified a blown Inductor. Im trying to recover my data only
                                          Reading between leads show nothing. If I removed this Inductor, what would be a suitable replacement? am I correct that its a ferrite Inductor is to just filter noise?
                                          Ive seen people just bridge them, any harm in replacing it with a differnt value Inductor?
                                          Lastly am I correct in thinking there is no polarity on the smd component?
                                          Thanks!...
                                          04-05-2024, 09:54 AM
                                          Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                          by momaka
                                          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                          09-19-2021, 08:44 PM
