LG 65uj6200 flickering haf buttom of the screen
  • kgavionics
    • Apr 2017
    • 152
    Hi guys
    I bought this 65" smart tv for 40$ from a lady who told me that the tv is dead and the screen is perfectly fine.i went home and turned out that the tv has a crack in the top right , but the tv works fine expect that spot and some vertical black line and the tv was watchable without any problem.
    after 2 weeks, the tv started flickering as you can see in the video.
    https://www.youtube.com/watch?v=XTJda_QDyfY
    I want to know if the panel is causing this or may the Tcon ribbons.i didn't take the tv apart yet, if it's the panel it a waste of time for me.
    i'm waiting for you input guys..
    thank you in advance
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 65uj6200 flickering haf buttom of the screen
    Yes that is caused by the crack. The crack spreads it eventually get into the control section for the gate drivers. It's losing capacity to run the horizontal span properly..
    It's causing a short and thats what your seeing.
    • kgavionics
      • Apr 2017
      • 152
      Thank you freakatr8 for your input. Your explanation is totally logical, but horizontal flickering is intermittent. I've uploaded a second video showing this
      https://youtu.be/b2F-ZZ0TYBE
      • freakaftr8
        • Oct 2012
        • 3743
        This will first be intermittent. Then after a bit it will become peminent.
        • kgavionics
          • Apr 2017
          • 152
          Thank you very much for the heads up. Eventually,i'm gonna part this Tv out.
          • Ado02
            Lenovo Thinkpad X1 Gen 10 - Flickering Screen
            by Ado02
            We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
            The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
            12-16-2024, 02:33 PM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • survivalbloke
            HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
            by survivalbloke
            SN: 8CG0213H8W
            ProdID 3C311UA
            This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
            05-08-2025, 12:21 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
