LC-46LE630E bad video after some minutes, phantoms or what?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4333
    • Italy - Milan
    Hi, this tv i have bought with the defect (also as said from the seller) of perfect audio video from the power on and after about 10 miutes artifatcs on all the screen that fades to an almost dark video with dark streaks. Tests made are that when defect occured AVDD and Von came off, pulled off the tcon and made some tests, especially warming up with the soldering iron on the chips and discrete semicon apart the main chip doesn't revealed the one sensible to hot, by my error i have put the iron's tip on a metal part of a transistor on the board supplied externally by a PSU, the tip is at ground and the fuse blewn, replaced the fuse the tcon worked again, but now it never stop working!! After 6 hours of function, switched on 2-3 times, no issues.. Like my other recent experience with Sharp panels ther's something magic that restores full function after only some simple tests on the board (maybe the running by an external PSU). So what i have to think?
    Thanks!
    THE TV IS SHARP MODEL
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LC-46LE630E bad video after some minutes, phantoms or what?
    Cold solder joints that get reconnected after handling?? Look at the pin connectors, etc for loose or weak joining. Sometimes they don't look bad but internally they are. Re-heat all joints if possible.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4333
      • Italy - Milan
      Ok so if i will put pressures on different point while switched on i might be see the defect...? I will try...
      • freakaftr8
        • Oct 2012
        • 3743
        So you are supplying an external power supply 12v tcon? Possibly drop o n voltage from original source was your problem?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4333
          • Italy - Milan
          No external supply only on some of the tests..
          No defect on the tv PS cause now tv is working from too much hours... some hitting tests then i'm near to resell it as working..
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4333
            • Italy - Milan
            Hi, no hit or pressures can make difference so i have closed the tv... bye
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Oh freaking looool...
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                The problem could have been a bad panel. I had the same with a philips , fine on start up and suddenly a black haze on the screen. Like a curtain......
                You could have tried to pull the tabs on the side of the LCD.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4333
                  • Italy - Milan
                  don't remembers me a panel problem, i'm almost sure the fault was in tcon, a panel can't make fine pitch artifacts like this.
