Help please....samsung j100H/DD overheating problem?
  • russell1981
    • Jan 2012
    • 32
    • bangladesh
    unable to open this application.your device is overheating!!!
    what can i do for this kind of problem?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Help please....samsung j100H/DD overheating problem?
    Try to reset it to its factory defaults. Maybe a app is running in the background that is causing the cpu to run at 100%.
    Could also be battery
    • russell1981
      • Jan 2012
      • 32
      • bangladesh
      nope....i did factory defaults.i have change battery and display.no hope!
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • Gibon378
        Problem with stopping audio and video for no reason
        by Gibon378
        PC Specs:
        • CPU: Ryzen 5 1600
        • GPU: GTX 1080 Palit JetStream
        • MOBO: ASRock ab350 PRO4
        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
        • PSU: XFX 650W (don't remember what model)
        • OS SSD: ADATA SP920
        • OS: Windows 10 21H2
        Problem description:
        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
        11-19-2022, 09:41 AM
      • perzyk23
        Lenovo T580 - LCD Panel problem - error 0288
        by perzyk23
        Good morning,
        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
        10-25-2024, 12:42 AM
      • lazaro.089
        Asus Zephyrus M16 / GU603ZW problem
        by lazaro.089
        Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
        CPU: Core i9-12900H
        Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
        Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
        The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
        08-26-2025, 06:33 PM
      • SDNarcia
        Dell 15R-5521 keyboard problem (KBC?)
        by SDNarcia
        Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
        As additional information,...
        07-20-2024, 10:47 PM
