vizio dead set
  • nosugartonight
    • 107
    • united states
    vizio dead set
    Kinda new to this so bare with me. This is a vizio E420V0. Completely dead,no power light,nothing. On the main board,"3642-0972-0150(41)" the 3v nano fuse is blown. From the fuse through a cap goes to u6 a IC or eeprom.not sure what it is. If I'm doing this correct with meter in diode mode. From pin one to last pin"straight across" It shows shorted. Thinking this is what I need to replace. I can't find it. The part number is LA8004PG AN08. I'm I on the right track.
    Re: vizio dead set
    https://www.badcaps.net/forum/attach...1&d=1516135770
    Are you saying that the white fuse by the connector of the main board that goes to the power supply is blown?
    • nosugartonight
      • 107
      • united states
      Re: vizio dead set
      No it the little gray nano fuse.right below the cable from the power supply. They are two fuse's one is 5v other is 3v.
      • R_J
        • 9551
        Re: vizio dead set
        I believe that ic is similar to a ap3435, pin 1 (Vcc) can be connected to pin 8 (Vin), It is a step down converter from 2.7v to 5.5v input to 1.2 volts output on pin 7, check if pin 1,8 or7 are shorted to ground (pin3 & 6)
          Re: vizio dead set
          Main board:
          http://assets.shopjimmy.com/media/ca...0150-top_5.jpg
          Power supply board:
          http://assets.shopjimmy.com/media/ca...1030-top_4.jpg
          The two fuses on the main board:
          F1 is for the 5V STBY, that 5VSTBY is fed to many circuits on the main board so shorts circuits can be any where that the 5VSTBY is connected to.
          F2 is for switched 12V.
          • nosugartonight
            • 107
            • united states
            Re: vizio dead set
            Pins3,6 and 7 show ground
            • nosugartonight
              • 107
              • united states
              Re: vizio dead set
              All voltages are good on power board. Is u6 an IC ? No voltage on any pin just as I suspect because fuse blown.
              • nosugartonight
                • 107
                • united states
                Re: vizio dead set
                Ok I didn't have a 3v nano fuse so I used a jumper wire. I now have back light but it is flickering really fast. Anyone have any ideas. Also will not shut off with power button.
                • R_J
                  • 9551
                  Re: vizio dead set
                  Yes u6 is an ic, it is a stepdown converter (post#4) What voltages do you have on its pins? Does it get hot to the touch?
                  • nosugartonight
                    • 107
                    • united states
                    Re: vizio dead set
                    Does not get hot or warm.pin 1-5.07 pin2- is all over the place,but slowly goes to 0 pin 3 and 4 - .796 pin 5- 1.6 pin 6- .9 pin 7- 1.850 pin 8-5.14
                    • R_J
                      • 9551
                      Re: vizio dead set
                      Because I am going by a different ic part number "ap3435" I can't be certain about what the exact output voltage on pin 7 should be, but it seems to be fine.
                      Pin 2 has no connection
                      pin 3 and 6 should be ground
                      See page 15 of the pdf
                      • nosugartonight
                        • 107
                        • united states
                        Re: vizio dead set
                        Yes I agree,it seems fine now that I seen the data sheet. Thanks for the link. Are you familiar with u18. That is a eeprom right. I looked at the voltages and two of the pins have high fluctuations reading. Where can I find data sheets
                          Re: vizio dead set
                          So right now the 5VSTBY Voltage is going up and down? and the resistance between GND and the jumper is?
                          You were using diode mode for checking for shorts:
                          Post# 1: 'If I'm doing this correct with meter in diode mode. From pin one to last pin"straight across" It shows shorted.' You should use Ohm mode instead.
                          • nosugartonight
                            • 107
                            • united states
                            Re: vizio dead set
                            5vstby is steady. As of now,when the set is plugged in. Black light starts flickering fast. Only way to shut the set off is to unplug. Voltages I was talking about going up and down is on u18, wich I believe is a eeprom.
                              Re: vizio dead set
                              How about the shorts that you indicated in POST #1? What is the resistance reading?
                              • nosugartonight
                                • 107
                                • united states
                                Re: vizio dead set
                                I guess I was doing it wrong. I was in diode mode. No sure how to check resistance in ohms. Ground to pin or pin one to each other pin . I would assume ground to pin.
                                • nosugartonight
                                  • 107
                                  • united states
                                  Re: vizio dead set
                                  Does anyone have any ideas on what would cause the back lights to flicker.I'm thinking it's in the main board because they start flickering as soon as the tv is plugged in ��
                                    Re: vizio dead set
                                    You can test the power supply/inverter board by itself by disconnecting the cable between power supply board and the main board then use 1K resistor between 5V STBY and the PS-ON pin, another 1K resistor between 5VSTBY and the BL-ON (I ON-OFF) to force on the power supply and the backlights when AC is applied to the board, the backlights should come on and stay on as as as the AC is present. If the backlights still do not come on then you will need another 1K resistor between 5V stby and the DIM pin.
                                    • nosugartonight
                                      • 107
                                      • united states
                                      Re: vizio dead set
                                      I don't have any resistors.I'll have to pick some up tomorrow and let you know how it goes. Thanks for the info.
                                      • nosugartonight
                                        • 107
                                        • united states
                                        Re: vizio dead set
                                        Was unable to find resistors.was thinking about robbing from old board.do you know the color code for 1k
                                        • Iain P
                                          Vizio E65-F0 really dead
                                          by Iain P
                                          Hi everybody!
                                          I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                                          So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                                          I decided to check the voltages coming off the power supply they are as follows:
                                          connector CN201
                                          pin 1 (18vsb1)...
                                          02-23-2023, 11:32 AM
                                          SHUTTLE XPC nano NC1010XA XPC nano 4205U Specification for Upgrade or Repair
                                          This specification for the SHUTTLE XPC nano NC1010XA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010XA boardview and XPC nano NC1010XA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:36 PM
                                          SHUTTLE XPC nano NC1010BA XPC nano 4205U Specification for Upgrade or Repair
                                          This specification for the SHUTTLE XPC nano NC1010BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010BA boardview and XPC nano NC1010BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          SHUTTLE XPC nano NC3000BA XPC nano 3865U Specification for Upgrade or Repair
                                          This specification for the SHUTTLE XPC nano NC3000BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC3000BA boardview and XPC nano NC3000BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        • dellxps15
                                          macbook a1707 15 inch trackpad dead. blown fuse identification
                                          by dellxps15
                                          hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                          another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                          04-30-2024, 10:48 AM
