UN60HU8500 no image has sound and backlights
  • tomstr
    Tommy
    • Jun 2010
    • 147
    • Usa
    I have a 60 in Samsung UN60HU8500 4k.. has no image has sound and backlights,without pausing I bought a T-con after my research, there is a lot of Samsung's doing this.. so I installed the T-con and same problem blank screen .. not giving up...I powered off the set re installed the right ribbon to my left, there are 4...pulled up the ribbon retaining clip re installed... then the pic started working,!!! So everything is great because I only paid 150.00 for the tv .. installed the tcon metal shield powered the tv on... no picture again back to square one.. after further checking in installing the ribbons to the t-con over and over the picture never changes... so I looked at the one ribbon causing the problem and there is the problem some of the gold contact was missing... and checking the the ribbons comming grime the mainboard... I found the same problem... BE CAREFUL WHEN REMOVING THE RIBBONS!!! USE A MAGNIFYING LENSE...now I had to order the damaged ribbons !! I will return with the results... I'm just wondering if people look at them closely??
  • freakaftr8
    • Oct 2012
    • 3743
    Re: UN60HU8500 no image has sound and backlights
    Interesting. Looks like cheaply made ribbons. Let us know if this solves the problem.
    • thoma
      • Sep 2012
      • 268
      https://cdn.badcaps-static.com/pdfs/...e27f7a8ad9.pdf
      • freakaftr8
        • Oct 2012
        • 3743
        Nice guide!
        • tomstr
          Tommy
          • Jun 2010
          • 147
          • Usa
          [QUOTE=thoma;795419]https://cdn.badcaps-static.com/pdfs/...e27f7a8ad9.pdf[/QUOTE
          This is a pic of the image on the screen as soon as it’s powerd on!! Then it goes blank then it just shows the back light screen with sound and no image? Also no power on jingle
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • iglitare
            by iglitare
            09-04-2025, 07:13 AM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • mecha1166
            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
            by mecha1166
            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
            11-25-2024, 05:22 PM
