Samsung un32eh5000f No backlight.
  • Nitro468
    • Oct 2013
    • 65
    Samsung un32eh5000f No backlight Can see picture with flashlight.
    I'm new to working on LED's fixed plenty of other stuff already.
    Powers going to LED
    CNL 802
    Pin 1 149.5 VDC
    Pin 2 128.2 VDC
    Pin 3 Not used
    Pin 4 128.2 VDC
    Pin 5 0.343 VDC
    What should I expect ?
    Any way to test the LED strips ?
    Thank You
    Chris
    Re: Samsung un32eh5000f No backlight.
    You have open LED sting that is connected between pin 4 and pin 5.
    Samsung BN44-00665A (L32GF_DSM) Power Supply / LED Board
    • Nitro468
      • Oct 2013
      • 65
      I was thinking open circuit with the readings.. Is there anyway to bench test them ?
      What voltage should I expect, I couldn't find a schematic or service manual for it...
        Right now you are getting 149.5V on pin 1 which is the Anode of the whole LED string, pin 5 is the Cathode return of the whole LED string.
        If you look at the Voltage chart as printed on the board, you will see LED Voltage of around 90V with load.
        You will have to open up the LCD panel assembly to get to the LED strips to test each one to see which one has open circuit. You will have to test each LED on the failed strip to find out which one/ones is/are bad.
        There are more than one version of the LCD panels used in this model, so you must verify what you have.
        http://www.shopjimmy.com/catalogsear...ng+un32eh5000f
        Fail LEDs are very common failure, when you get it fix make sure you turn down the backlights level.
        • jbfr_54
          • Dec 2012
          • 52
          • France
          Testing and fixing the LEDs is quite easy and inexpensive but watch carefully when you dissassemble and reassemble the panel. Due to the fact the panel has no screws but only pop-up tabs on the plastic surrounding the LCD, it is is difficult to open and necessitates to put force on the frame for dissassembling. Worse is reassembling as each of the frame tabs must be pushed toward LCD to be locked, again it is necesary to apply important force and the tabs click strongly agin the panel. So, last week, one fixed screen broke by itself without any mechnical strenght or move of the set two days after fixing. I imagine the lcd was broken on the edge for a few 1/10 inchbefore being broken on several inches on the high left hanside corner, probably due to temperature changes. Too bad they switched from screwed metallic panel frames to plastic clipsed system !
          • thoma
            • Sep 2012
            • 268
            http://forum.iwenzo.de/grundig-servi...e--t61847.html
            see also here
            • Nitro468
              • Oct 2013
              • 65
              Thanks for the explanation on the voltages, I had the feeling it was the strips... Disassembly was a bit of a pain, thank god it wasn't a bigger panel... There might be firmware update to address the LED life issue, but I will turn them down....
              • ossroy
                • Feb 2019
                • 18
                My Samsung UN32EH5000F is having a very similar problem. Rather than NO backlight, I have a very dim picture. I don't need to use a flashlight to see the picture, but can just see it in the ambient light of my bedroom, which is far from well lit. It does occasionally flicker, getting ever so slightly brighter or dimmer, but it is way too dim to be of any use. Adjusting the backlight setting has no effect. So I replaced the T-CON board after reading that it's a common problem with the backlight and it was only 12 bucks with shipping. Symptom did not change. So now I'm thinking the PS board and not the LED strips since there is some bit of brightness. If it was a bad LED, my understanding is the screen would be totally black. Does this sound correct? Thanks for any thoughts you may have.
                Roy
                  • 12269
                  • U.S.
                  @ Roy, Test connector from mainboard to powerboard on powerboard side, sholud be a little legend/map of expected voltages, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description and condition on and off, demonstration in signature below.
                  • neilc6
                    • Nov 2015
                    • 1550
                    You most likely need full LED strip replacement. Samsungs do not have protection to shut offf the LED supply so backlights will continue to burn out until the screen is dim. You can force the backlight on by unplugging the cable between the main and power supply board. Fairly simple to remove the panel on a 32 inch TV but you still need to be careful. Lower the backlight level on all inputs and all smart apps to around 60 to 70 after replacement.
                    • ossroy
                      • Feb 2019
                      • 18
                      Thanks guys; I'll open her back up this evening when I get home from work and check things out.
                      -Roy
                        check out this thread: https://www.badcaps.net/forum/showth...ung+ue32eh5000
                        Also perform main board disconnect to see what will happen to backlights.
                        • ossroy
                          • Feb 2019
                          • 18
                          With TV plugged in, but OFF:
                          Pins 1-13 (odd) No voltage
                          I didn't measure 2-14 because pins were inaccessible.
                          With TV ON:
                          Pin Label Voltage
                          1 B13 13 VDC
                          3 B13 13 VDC
                          5 Vamp 13 VDC
                          7 Vamp 13 VDC
                          9 GND 0 V
                          11 B5V 5.2 VDC
                          13 B5V 5.2 VDC
                          Pin Label Voltage
                          2 PWM 1 VDC
                          4 B13 13 VDC
                          6 BLU 4.8 VDC
                          8 GND 0 V
                          10 GND 0 V
                          12 A5V 5.2 VDC
                          14 PS 3.5 VDC
                          I had to unscrew and flip the board over to measure the even pins, taking great care not to short the pins with the probe tip.
                          -Roy
                            • 12269
                            • U.S.
                            Did you unhook cable from mainboard to powerboard, see if backlights come on and stay on? as suggested in post #10.
                            • ossroy
                              • Feb 2019
                              • 18
                              I unhooked mainboard from power board while TV was powered down, and TV would not turn on in that condition. Should I have unhooked them while TV was powered on?
                                • 12269
                                • U.S.
                                No, you did it right.
                                  With TV ON:
                                  Pin Label Voltage
                                  1 B13 13 VDC
                                  3 B13 13 VDC
                                  5 Vamp 13 VDC
                                  7 Vamp 13 VDC
                                  9 GND 0 V
                                  11 B5V 5.2 VDC
                                  13 B5V 5.2 VDC
                                  Pin Label Voltage
                                  2 PWM 1 VDC
                                  4 B13 13 VDC
                                  6 BLU 4.8 VDC
                                  8 GND 0 V
                                  10 GND 0 V
                                  12 A5V 5.2 VDC
                                  14 PS 3.5 VDC
                                  -Roy
                                  You can use skinny probe tip to access the Even number pin via the wire entrance of the connector.
                                  What does not make any sense to me is that you reported " Rather than NO backlight, I have a very dim picture" but you also report "Pins 1-13 (odd) No voltage". If B13V is not working then the T-CON cannot be working either.
                                    When you unhook the cable between the main board and the power supply board then plug the TV into the outlet, that will put the power supply and backlights driver circuits into self-test mode (it the board has pull-up resistors), so if the power supply, LED driver circuits, and the LED strings are OK then the backlights should come on and stay on as long as the TV is plugged in.
                                    At this point you need to report the Voltage on the power supply connector that goes to the main board and also at the LED connector (LED connector in place).
                                    BTW: Line Voltage: 170V P-P @ 16.6ms. That should be 120 V RMS X 2.828 = 339.36 V P-P.
                                    • ossroy
                                      • Feb 2019
                                      • 18
                                      I didn't have any skinny probe tips, so I just ordered a set from Amazon this morning.
                                      As far as the No Voltage on pins 1-13 (odd), that was when the TV was plugged in but turned off. As shown above, I did have 13V on pins 1, 3, 5 and 7 when the TV was turned on. Or should have I have seen voltage there with the TV turned off as well?
                                      -Roy
                                      • ossroy
                                        • Feb 2019
                                        • 18
                                        I will have to try again tonight. I had other obligations last night and never got a chance to look at the TV, and now I'm second guessing myself on what all happened on Tuesday.
                                        Now that's embarrassing! I used the formula for Peak and then wrote P-P.
                                          09-07-2024, 05:50 AM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
