I've been looking around these fora since I have an LC-70LE757U Sharp flatscreen TV and it has the same problem as many other cases but not exactly the same. When you plug it in, the Sharp symbol on the bottom flashes the 2 long and 5 short signals that something is wrong with the T-Com board. I found this attached support letter which helped somewhat. The T-Com has four ribbons attached to it and, with all of them unplugged, the backlight comes on. With one plugged in, there are some lines down the display on the left. With two plugged in just backlight. With three plugged in, the two inner ribbons and the left or right ribbon, the left and right sides respectively work. I tried resetting it by holding the input and volume down buttons while plugging it in and it just started normally. I can buy the T-Com board for $80 on eBay but I've heard that it's been replaced before with no success. Anything else that I should test? Thanks for the help
Sharp LC-70LE757U TV not working (2-5 signal)
Re: Sharp LC-70LE757U TV not working (2-5 signal)
Its unlikely that its a tcon issue. More likely that you have a panel problem. Lots of thread for this type of set. Basically, you need to leave all cabling in place on the tcon. At the bottom corner of the panel (at each side), there is a small ribbon cable which interconnects the bottom edge boards to the side edge boards. Disconnect this cable (either end) and check the resulting display. Repeat the test doing the same for the other side. Post pictures of the results and you can go from there. -
You said to disconnect the ribbon cables in the corners of the panel which I did. There is a small ribbon connector in the bottom left corner and one in the bottom right corner of the panel that I disconnected from the side edge boards on either side. When I disconnected both of those ribbon cables but kept the four ribbon cables connecting to the T-Com to the bottom edge plugged in this is what happened to the screen. I had backlight unlike when the two smaller ribbon cables are connected but anything that the screen displays shows up as multicolored lines.Comment
we have a bit of a "communication problem". :-) I didn't say to disconnect BOTH of the corner cables at the same time.... if you read that in to it... then how would you do the "repeat the test for the other side". Anyways, it doesn't matter as it appears eventually, you did have only one corner disconnected. The pictures that you posted show you have a panel error with one of the tabs on the side.... that's the horizontal line that you see.Comment
what the result with the "other way around"?Comment
That indicates that side that remains connected is bad and the set can't create a "picture" using it. Your first "test" used the "good side" with the "bad side" disconnected and thus could cause a picture since the "bad side" was now removed... confused yet... :-)
Anyways, the tv can't be fixed, it can only be saved... that is, the tabs along the bad side are removed. The result is an "perfect picture" ... "perfect" in terms of general watching but a "discerning viewer" may notice some issues since the screen is being driven by only one side of electronics.... hence the "save". There are lots of posts on the "success" of this "technique" to get a working set. Search the forum and you will find many. One note: once the tabs are removed, they can never be put back (its a one way street), hence you need to be certain that you are removing the bad side and further that you have no other recourse (ie. warranty or otherwise).
Still further, your comment about the "left ribbon plugged in, right one not" gave you the pictures that you posted... doesn't quite jive....again somewhere we are "miscommunicating"... the pictures show the horizontal line coming from the left and fading / disappearing on the right. This is likely not possible in my opinion.... of course, you are possibly referring to the "left and right" positions from the back of the set.... my guess. You need to be very certain of your word references otherwise we may "miscommunicate" again and it might result in you removing the WRONG tabs. :-(Comment
If you remove the ribbons on the bad side the picture will return to normal. As budwich stated there are many threads on this already do some reading so you can get up to speed on what needs to be done and why.Comment
So I've taken off the bezel of the TV and I can access the bad side panel for the display that was NOT working when tested. There are five ribbon cables (not detachable) that go from the edge panels to the LCD display. I have pictures of what I have so far. You're saying that if I detach these five cables from the LCD then the screen should "work" again? If so how do I detach them correctly, I've been looking for hours and I can't find a solution.Comment
basically you just tear them away like pulling tape off something. You need to ensure that the contacts there after are clean / clear of any remnants there after. The side edge boards can then be unclipped from the holders and removed as they are useless thereafter.Comment
Just fixed my LC-70LE757U last night. Although in Spanish, great YouTube video here that helped me: https://youtu.be/xXNTKYDLD5MComment
Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...11-23-2023, 11:02 PM -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by JayPoorJayGood morning.
I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions... -
by ScruitHello all,
Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
https://imgur.com/gallery/PpqcqPY
My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
More detail:
Symptoms are that that I get... -
by supravit2000Hi, guys!
I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so... - Loading...
