43mv314x/f7 blown Power Supply
  • dabone
    • Aug 2010
    • 30
    I was handed a 43mv314x/f7 to look at and on first inspection, no power, no led. So I opened the unit, and have been looking at the PSU.
    It's a BA4DV2F0102 2, and doing a quick check of the though hole components, the main fuse is blown, q601 (K7A6QX) is a dead short, and one diode on the low voltage side D655 (SB3A0) seems to be dead also .
    My searching has come up empty on this model. Does anyone have suggestions for this one, since I'm seeing multiple blown parts, I'm guessing it has taken out some of the surface mount stuff on the flip side.
    Thanks.
    Later,
    dabone
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • cheeky2
    Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
    by cheeky2
    This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
    I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
    Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
    06-15-2025, 05:12 AM
    03-31-2024, 02:12 PM
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
  • Babbar
    by Babbar
    04-12-2024, 01:12 AM
