Need bios dump DVR h.264 network
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Hy , when switched on, only displays colored bars.
    I think the problem is a bios dump, model is a dvr-6104d and chip is 25Q128FV
    Thank
    Fabrizio
  • skyx
    • Jan 2017
    • 17
    • iraq
    Re: Need bios dump DVR h.264 network
    me too>>h.264 bord model Hi3515 8CH
    • Diah
      • Feb 2013
      • 6589
      take out the spi from boards and make dump of the firmware after you freezing it with air cool (very important to have clean fault free dump ).. the dump you can flash it on new spi 25Q128
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
        by haitham sharabati
        Hello engineers 😀,
        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
        💀 Problem:😅
        - Device shows “Administrator Password”...
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
