Sharp LC-80UQ17U no power no codes works if unplug and plug back in
  • Skerrvydog
    • Dec 2017
    Sharp LC-80UQ17U - my father in-law's TV. Won't turn on with hard buttons or remote. No blinking LED indicators up front. Unplug set and plug back in and it works fine, for a day. Sits overnight and same issue - dead until i unplug it and plug it back in.
    First thought was a power board problem so i ordered a salvaged power board and swapped it in, but the problem persisted.
    Any ideas? would this set store codes internally that would perhaps prevent it from powering on until the codes were reset? Would this be a problem with thee main board?
    I didnt do anything after installing the new power board in the way of reset or anything, ios there something else i need to do?
    A tech from a local TV repair shop is coming on friday to check it out, so im trying to get info and ideas before he gets to it.
    All the "no power up" threads ive turned up all deal with error codes - if the set does not show any error codes, what should i do?
    TIA for any help here. Been and AV installer/programmer since 2000 and dealt with my share of Sharp TV errors and malfunctions, but this one has me flummoxed.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sharp LC-80UQ17U no power no codes works if unplug and plug back in
    If the control buttons do not power ON/OFF the TV but CH-UP, CH DN, VOL-UP and VOL DN works, it could be the Key Bd. has a problem. However, if you cannot change the channel, vol, etc also then it could be a Main Bd. problem.
    • michalk3777@gmail.com
      Sharp Hisense - LC-65N7004U Error codes
      by michalk3777@gmail.com
      Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
      Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
      Regards,...
      12-15-2024, 09:20 PM
    • oneduane
      Samsung Plazma Blues Model PN59D550C1F
      by oneduane
      I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2...
      09-07-2023, 08:17 PM
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
    • DynaxSC
      GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
      by DynaxSC
      I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
      General test conditions:
      - Tested with Core i5 6500 and Core I7 6700K - no difference
      - Default BIOS settings, but tried also altering several memory setting - does not change anything
      What is wrong:
      With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
      When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
      03-21-2025, 06:23 PM
      HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
      This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
      09-12-2024, 02:30 PM
