LG 55UF6450 4K Colored Ants Fighting
  • Michale32086
    • Nov 2011
    • 1453
    While I am digging out the other 4K, wanted to get some insight on another 4K that came into the shop this weekend..
    LG 55UF6450... Has a great clear picture until a device is plugged in.. Then all I get is colored "static"...
    I was thinking Main Board, but I have a sneaky hope that it's just the TCON...
    Cleaned and reseated the LVDS cables.. No luck...
    The picture is kinda hard to make out the static, but it's there...
  • Tech3031
    • Nov 2014
    Re: LG 55UF6450 4K Colored Ants Fighting
    Main board is bad. I've had a couple of these set's, replaced main board & fixed. Expensive part, waited 2 months for part from parts distributor.
    • freakaftr8
      • Oct 2012
      • 3743
      Check grounds on H DMI sockets make sure that it's properly grounded you could try to you take a wire and ground the H DMI socket directly to chassis ground to see that helps
      • Michale32086
        • Nov 2011
        • 1453
        Thanx for the replies. I was thinking of putting up $$ to replace the TCON, see if that would fix it..
        Sounds like it's a waste of money...
        I'll try the grounding idea...
        Thanx again ya'all...
        • Nick's Tvs
          • Jan 2014
          • 621
          These main boards commonly fail on this model, but like mentioned previously they are almost impossible to find unless you are willing to spend $370 from encompass parts.
          There are repair service available online that are cheaper such as the one linked below:
          https://www.ebay.com/itm/Main-board-...0AAOSwGG5aKXTI
          • MASTER_TECH_101
            • May 2018
            • 12
            So is it XD chip bad?
            Do you reball them or replace?
              • 12200
              • U.S.
              Is it only from hdmi source, did you try rca or component input?
              • Michale32086
                • Nov 2011
                • 1453
                If I remember correctly, it was from all sources.. I think I still have this flying around.. I'll pull it out and check it...
                  • 12200
                  • U.S.
                  My bad, didn't realize it was 4 months old.
                  • Eel_dahc
                    • Apr 2017
                    • 18
                    I grabbed a 55UF6430 from the dumpster. Same board as the 6450 it looks like. It came on, had the menu but hdmi and channels were the colored ants like stated. Well, I followed some youtube videos and baked the board like I used to with xbox in the toaster. Before doing so I noticed that there was a bow in the middle of the board like the processor was sinking through it. So I placed it onto a circular piece of metal hoping that when it was heated for a while that it would flatten out. I first let it sit for a few hours on the lowest heat to make sure it was dried out okay. Then I put some flux around the chip, ramped it up to 200c ish and let it stay like that for 10 minutes then cranked it up more then off and opened the door. I tried it out and it's still the same thing, although the bow is now gone and I can see the bga balls. But now the board is brownish from the flux residue and the stickers shriveled. Is there any way some repair shop would even look at it now if I attempted that?
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      No.
                      • Hamie
                        • Apr 2014
                        • 1383
                        Why do people keep baking boards.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          They read it on the Forum and in desperation try it in the hope of getting a few more months of use.
                          • Eel_dahc
                            • Apr 2017
                            • 18
                            I did it because it was free. A crapshoot. Figured I could get another board if it didn't work. Should have looked up how scarce they are first. Now it will wait in a corner with an ebay alert set for another board.
                            • Unspun01
                              • Jun 2011
                              • 345
                              The problem is the main BGA IC. Re-balling is not a fix as it is problem is inside the IC. You need to replace the main BGA IC. This is problem on many of these similar LG 4K LED TVs.
                              • spice_disc
                                Vizio TV M50-C1 reboot cycle and static on screen
                                by spice_disc
                                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                09-08-2024, 02:37 PM
                              • mon2
                                Crate guitar amp with extremely loud static on power on (no input)
                                by mon2
                                Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
                                07-18-2025, 06:40 AM
                              • PNI E.
                                Tv grundig 50vlx21ldl horizontal colored limes
                                by PNI E.
                                Good morning guys, I have this tv that have horizontal colored lines ( green, blue, black). I tried to disconnect the two ribbon cable on the t con, first the left side and then the right side. But the lines still are there…so I tried the tape method but didn’t work. Can someone help me to try to fix this tv. I give you the photo of the panel, and the panel with the left ribbon unplugged and then the right. Thanks for your help...
                                06-11-2025, 09:45 AM
                              • diggitt
                                Radio, no stations, quiet static sound
                                by diggitt
                                I am repairing a DeWalt DC011 radio. I found that the secondary coil of the transformer had gone open circuit and the amplifier ic had shorted. I have replaced both but I can’t tune it in to a station and the static is very quiet. Any help is greatly appreciated. Thank you
                                04-14-2025, 05:06 AM
                              • EazyBone
                                LG 75UH8500 color static frozen
                                by EazyBone
                                Got a LG with color static frozen. Doesn't move just stays on this picture. I'd assume it's main board but I'm sure one of you has seen this before. Any data helps thanks...
                                06-10-2024, 09:35 AM
