Help with Sony KDL-46XBR4
  • wtuser
    • Nov 2017
    • US
    I had an issue with my XBR4 with no backlight and intermittent picture/sound outage. Narrowed the issue down to no 3.3v backlight trigger from AU board. Ended up replacing AU board and FB1 board to get the trigger. Now, I get the backlight and the menu but still no picture or sound. I know I have to update the serial/model of the unit but I'm unable to figure out how to change this. I've already tried service menu but don't see a place when I can change this. Could somebody help with this?
    I did notice after replacing AU & FB1 boards, the serial/model is different so I know I have to change it but not sure if no picture/sound is because of that or I still have issue with AU board.
    Any help on this would be greatly appreciated. TIA
  • budwich
    • Jul 2015
    • 3097
    Re: Help with Sony KDL-46XBR4
    funny I just came across a non-working 46xbr4... :-( but in my travels came across some stuff.
    To update the FB1,
    you go into the service menu (you say you know how), then press "jump" until the BEM micro serice menu displays.
    then press "2" until the 001 model_info category displays. Use "3" or "6" on the remote to increase or decrease the value ... "0" is for 40", "1" for 46.
    to write into memory, press "muting" and then "0" on the remote. exit service mode via the power off.
    NOTE******** I don't know if this works, it is just based on readings... don't know how dangerous it is either.
    • wtuser
      • Nov 2017
      • US
      Thanks for that. I actually came across those steps as well. I did change the model_info to correct size but I didn't see a place to change the actual model/serial# (Original: KDL-46XBR4 with 800xxxx serial# & After replacing FB1: KDL-46XBR5 with 821xxxx in the support info). I was hoping I could change these in the service menu like you mentioned but haven't been able to find a place to correct it.
      I still have no picture for digital inputs (HDMI/component) so may be I'll put the original AU board back in to see if FB1 board was the problem all along. I wouldn't think incorrect model/serial could cause no picture condition, could it?
      Thanks again for your input.
      • budwich
        • Jul 2015
        • 3097
        You are past my limits of read... but once in the service menu, you use "jump" to go to various "submenu"... one of those holds the model.... its before the FB1 change.
        Further, in my travels in sharp with a different main board, we had to change some "jumpers" to adjust tv size (46->42) and then had to do a factory reset to get things going. maybe sony has the same requirement.... ie. reset
        • CyberPhoenix
          Issue with picture quality of Sony bravia TV
          by CyberPhoenix
          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
          01-22-2024, 02:08 AM
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • Ierwin
          Philips 58PUS7805 Menu working but no/weird picture from video sources
          by Ierwin
          I got a 58pus7805 that shows some weird behavior.
          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
          I managed to install the latest official firmware by holding the control button while plugging...
          03-10-2024, 12:50 PM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
        • tree5656
          diagnosing sony XBR-75X900H. NO PICTURE
          by tree5656
          This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
          11-09-2023, 04:55 PM
