Just picked up a 55 inch LG 4k OLED for $50!
  • kevlar51
    • 32
    • usa
    #221
    Re: Just picked up a 55 inch LG 4k OLED for $50!
    It's currently set up as UA board and UA t-con, and not working. When I get a chance, I'll put the UB t-con and cables back in and see how it starts up. Might possibly need to order another T-con if things don't improve and I can't get the UA working again, but I still don't understand why the UA/UA configuration suddenly crapped out.
    And then in the end, I'd still like to figure out how to get UB/UB working if possible.
    • kevlar51
      • 32
      • usa
      #222
      Originally posted by freakaftr8
      So is your set working now? With your UA board and UB tcon? If so, I would suggest running it for a few days without slapping it back together just in case my theory is incorrect, and the picture does not straighten out.
      And when you mentioned half panel was black, was this left/right or top/bottom w the UB mainboard and UB tcon? And your UA nainboard produces a full image with the same UB tcon installed?
      On my first attempt with the UB/UB configuration, the right half was black, left half was "no signal" image, and no inputs seemed to work. All of the cabling seemed well seated. The same UB T-Con gave me a full screen with the UA mainboard. When I got the UB Tcon working with the UA mainboard, I was using the shorter UB cables.
      • freakaftr8
        • Oct 2012
        • 3743
        Your UB mainboard is bunk that you got. I would exchange it. Prob had firmware issues or bad BGA under main processor.
        As for your original config (UA and UA), I would suggest the reset like I mentioned with the button.
        Theres no reason the UB/UB config wont work properly, all UA/UB panels are the same.. The LC650LQD / LC550LQD panels with the GH P** whatever should all be able to operate UA/UB with no problems.. My Frankenset is living proof.
        • kevlar51
          • 32
          • usa
          #224
          Your UB mainboard is bunk that you got. I would exchange it. Prob had firmware issues.
          Do you think a similar reset might work on the UB mainboard? This was an ebay purchase with "no returns"--but I think it's protected through an ebay guarantee. Sucks because UB mainboards are hard to find. I've got the most recent firmware update ready and waiting on a USB stick, but it doesn't do me any good if I can't keep it powered up for more than 5 seconds.
          • freakaftr8
            • Oct 2012
            • 3743
            Probably not.. You can try the button resets, but i doubt it.. Its probably someone elses return from the same issue..
            My original UA mainboard went out. But this was in my original force starting with the failed panel. I shorted eeproms 3.3v to ground on accident. Luckilly UA mainboards are easy to come by
            • kevlar51
              • 32
              • usa
              #226
              I'm fully swapped to the UB T-con, UB cables, UA main board and I'm up and running again.
              Unfortunately the reset button didn't seem to do any good with my original UA t-con. Should I consider it toast?
              I did swap over to the UB main board again, and successfully used the service remote to get back to the image, unfortunately it was still only showing a picture with half the screen, though I was able to navigate menus on the left side with the remote. I also noticed when switching inputs that it wasn't actually a black screen, because the "TV" input yielded static, and the right side was a streaky mess of static--so it only looked black on other inputs because the screen was otherwise black anyway. I did notice on the power-only screen that the firmware rev is up to date.
              I fooled around with the service remote trying to find an option that would help and I must have screwed something up when i hit "in stop" because the picture went out entirely--though audio worked (Static sound on TV input). Even power-only wouldn't get me a picture on the screen.
              But swapping back to the UA main board got me back to normal.
              • freakaftr8
                • Oct 2012
                • 3743
                Yeah your UB mainboard had issues. It's probably the main processor. I'm going to attempt to install my UB mainboard into mine this weekend. This has me intrigued. I'll let you know the results.
                If I were you I would return that UB and either try to find a good one or just it like it is currently.
                Is the picture getting better with the vignetting you were telling me about?
                And yes your UA tcon bit the dust. You may have static discharged into the eeprom which wiped out its initial settings. This is exactly what the UA t con was doing to me that is the same one as yours with the longer cables. I couldn't get it to display an image to save my life.
                I believe it is an early revision tcon . One of the 1st ones when they had a design that was going to put the power supply on the right side and main board on the left however for some reason they decided to put the main board on the right instead. Also I noticed some early OLED tv s that were sold in the Asian markets that had the boards on opposite ends.
                I believe this was probably due to them running off the rest of the tcons that were manufactured So they could use them out before the changeover to the new style which is the one you and I have in our TVs now
                • kevlar51
                  • 32
                  • usa
                  #228
                  I'll need to run the picture through some motions to really test if the vignetting is gone. The picture issues I described before would best be described as mura with some light banding. But for the most part you only notice it on light gray, uniform pictures, which is tolerable if that's it.
                  I'm fully swapped to the new T-con, new cables, old main board and I'm up and running.
                  I did swap over to the UB main board again, and successfully used the service remote to get back to the image, unfortunately it was still only showing a picture with half the screen, though I was able to navigate menus on the left side with the remote. I also noticed when switching inputs that it wasn't actually a black screen, because the "TV" input yielded static, and the right side was a streaky mess of static--so it only looked black on other inputs because the screen was otherwise black anyway. Tried reset buttons which didn't seem to do any good and at some point the picture went out entirely--though audio worked (Static sound on TV input). Even the service remote wouldn't get me a picture.
                  I'll do my best to get my money back on the UB mainboard, but I don't have the highest hopes. Can't decide if I want to go down this hole again if I see another UB mainboard pop up. We'll see. I'm curious to find out what you see this weekend.
                  Thanks a ton for all your help and feedback.
                  • kevlar51
                    • 32
                    • usa
                    #229
                    So if I can't return the UB board, think I should try the oven trick?
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      The oven trick usually does more harm than good if you have access to a heat gun or a good hairdryer you could try heating up to the main processor in areas around the board. However I wouldn't go much further until I try my board in my TV. At least at that point we know what we're dealing with.
                      • kevlar51
                        • 32
                        • usa
                        #231
                        The "half screen" issue is really throwing me off though. I'm very much a beginner at this, but I wouldn't think that a half screen picture error would be a mainboard issue. But It's only present with this mainboard, so that would indicate otherwise.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          On a normal led/lcd/plasma TV has screen issues are usually related to a tcon or failed panel. The more I think about it the more it makes me question if it is in fact a bad main board or an incompatible main board. Not knowing the inherent pinout configerations I'm not sure if a main board can produce half image.
                          The only thing is the fact that that tcon will give a full image with a different main board so this is really odd.
                          And considering a UB tcon works in a UA panel, Also I'm not convinced that there are inherent differences within the panel itself, I have seen threads from different websites stating that the UB equipment does not work in a UA. I guess I'm just not convinced unless a grab the bull by the horns and do it myself miss my TV since I have it all here .. Then we will know for sure
                          • kevlar51
                            • 32
                            • usa
                            #233
                            Yep, I'll hold for your results--thanks
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              IT WORKS! The UB mainboard works the TV is officially a UB with HDR support!!
                              It's your mainboard man.
                              • kevlar51
                                • 32
                                • usa
                                #235
                                Nice.
                                Part of me was hoping it would give you the same issue so that I could definitely rule this out and stop worrying about it
                                Now I guess I need to be on the lookout for another UB mainboard...
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Yep. Mine though, my HDMI ports are dead... I fried a voltage regulator a few weeks back when I pulled a dumbass move and ran the probe across 12v to ground. I replaced the regulator but fried the ferrite coil. I ran a bead of solder to jump it but guess it needs more work.
                                  • kevlar51
                                    • 32
                                    • usa
                                    #237
                                    can you tell me what firmware it's running?
                                    the practical difference between the UA and the UB is the HDMI 2.0a ports on the UB (thus able to display HDR over HDMI)
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Just updated. Had 4.20.75 now has 4.25.40
                                      • kevlar51
                                        • 32
                                        • usa
                                        #239
                                        Cool--that's not available on the UA model
                                        • kevlar51
                                          • 32
                                          • usa
                                          #240
                                          Just to confirm--firmware changes only affect the mainboard, right? no affect to T-con, etc?
                                          • djordje
                                            Philips 55 oled 804/12 red light blink
                                            by djordje
                                            Hello all,
                                            I have Philips Oled 55 (804/12) with black screen and red light blink.
                                            I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                            Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                            When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                            My questions is what should i do next...
                                            01-03-2025, 04:00 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
