LG 60lb5200 LCD TV - No Power - No Standby Light
  • Landon6544
    • Dec 2017
    • 15
    Hi. Just bought a repair project. LG 60lb5200 has no standby light. I've tested the pin voltages on the power supply and get nothing on any of them. The symbol on the bottom pin reads 'EN'. I assume this is the standby voltage out? I've searched other posts, but can't find this abbreviation mentioned. I tested the main transformer outputs and got nothing. The fuse is good and reads normal AC voltage across it. Can someone lead me in the right direction with narrowing down the problem component? I'd rather not have to pay $100 for a new board.
    I've included pics.
    Thank you!
  • PotShotScott
    • Feb 2007
    • 40
    Re: LG 60lb5200 LCD TV - No Power - No Standby Light
    I don't have any experience with this particular TV but some of my Navy Avionics course training is coming back to me (it's been 26 years since A school). I'd be looking closely at the diodes that feed into the transformer. They might be part of a rectifier circuit that drives the transformer that feeds into the DC/cold portion of the board. Maybe one or more of them died and they just "look" okay?
    • freakaftr8
      • Oct 2012
      • 3743
      Can you check the main primary side capacitors? Negative lead black positive lead red to each side of the capacitor while it's plugged in on DC voltage you should be reading about a 170 V DC.
      Location C9 or C10
      • CapLeaker
        Leaking Member
        • 8327
        Check D3 and D9 for a short on the secondary. One of them is for 12V, the other for the 24V rail. What is written on U1?
        • Landon6544
          • Dec 2017
          • 15
          Ok, I checked D3 and D9. Those are the three terminal voltage regulators on the DC side, right? I'm getting 0 volts.
          Also, I noticed when I move the board that I hear something rattling in one of the components. Sounds like little pieces of loose glass or metal. Could that be from the transformer?
          • Landon6544
            • Dec 2017
            • 15
            C9 and C10 both read 167v DC.
            • Landon6544
              • Dec 2017
              • 15
              A bit more... D3 and D9. Are those MOSFET transistors? I'm learning a lot already. Haha. I'm pretty sure the noise is coming from the varistor, or brown box down near the fuse. Is that supposed to have loose pieces inside?
              I also tested the bridge rectifier on the hot side. Getting 167v DC across the positive and negative terminals, and around 120v AC on both of the middle inputs.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                D3 and D9 are the subscripts for Diodes.
                • Landon6544
                  • Dec 2017
                  • 15
                  Well, I initially assumed that D stood for "diode", but the component has three terminals, although there's also an 'M' designation there. I can't read the part number because of the heat sink. I only learned basic electronics, and that was in Air Force tech school back in 2002. So... I'm learning and refreshing. The heat sink on the hot section is attached to similar looking components, but they have a Q. I'm guessing those are transistors.
                    This is an always on power supply to supply 12V and the 24V, it also has PFC Voltage booster.
                    What is the resistance reading of R33?
                    Can we see the whole backside of the TV showing all the boards and how they are connected together?
                    More likely the AC feeding this board is done through a switch.
                    • Landon6544
                      • Dec 2017
                      • 15
                      Oh wow... I just noticed that the board is burnt underneath that resistor. The ohm reading is 11, 700 Ohms. I can't tell what colors the stripes are, though.
                        What is the P/N of the 16-pin SMD IC U1 in that section of the circuit?
                          http://www.shopjimmy.com/catalogsear...?q=LG+60lb5200
                          LG COV32809701 Power Supply
                          http://www.shopjimmy.com/lg-cov32809...wer-supply.htm
                          R33 looks to be 10K resistor based on the pictures from shopjimmy.
                          Pictures provided by shopjimmy.
                          • Landon6544
                            • Dec 2017
                            • 15
                            Ha, it looks nothing like those colors on my board, but it's reading 10.6k. So, even though it looks burnt, it seems to be reading within tolerance? And... I don't see any IC chips on the power board. Do you mean on another board?
                              The IC U1 is right on the bottom side of that power supply board. I hope you do have the tools and know how to do SMD repair.
                              10.6K is good enough, but something is drawing too much current through that resistor.
                              • Landon6544
                                • Dec 2017
                                • 15
                                Man... I'm really having trouble reading it. Might need to find a magnifying glass. If I can determine that it IS the IC causing the issue, I might be able to get it fixed. I don't have the tools for soldering something that small.
                                  Without the IC P/N to get the specification sheet of the IC, then there is no way to find out if the IC is getting the VCC to run or not, and that 10K resistor looks to be connected to one of the IC's leg.
                                  • Landon6544
                                    • Dec 2017
                                    • 15
                                    Ok, this is actually the same model that another member is having issues with, and you asked him the same question. He's getting voltages on his pins, however. They're just too low.
                                    Anyway, the printing is clearer on his IC chip. I've included the manual for it.
                                    • Landon6544
                                      • Dec 2017
                                      • 15
                                      What do I need to test to isolate the IC chip as the culprit?
                                        See my post #17 about the VCC.
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • jasonbay13
                                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                          by jasonbay13
                                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                          12-01-2023, 09:55 PM
