Samsung un75ju7100fxza won't turn on
  • Luey305
    • Nov 2017
    • 8
    Hello badcaps.
    I was given a Samsung un75ju7100fxza that doesn't turn on however the red light on the bottom of the TV stays on and blinks when I try to power it on. A little background info on this TV might help, the ground on the power cord was removed so that it can be plugged into a extension cord that didn't support 3 prongs.
  • CapLeaker
    Leaking Member
    • 8326
    Re: Samsung un75ju7100fxza won't turn on
    Unplug the TV, remove the main board from the PSU, then plug the TV into mains. When you do this, the PSU should come on and the backlights should be light.
    • Luey305
      • Nov 2017
      • 8
      Thank you for your help. I did what you said and I get no Backlights.
      • CapLeaker
        Leaking Member
        • 8326
        How good and comfortable are you dealing with power supplies? Do you have tools?
        • Luey305
          • Nov 2017
          • 8
          Well I never worked on power supplies, however I am comfortable around electronics and yes I do have tools.
          • CapLeaker
            Leaking Member
            • 8326
            The primary (HV) side of the PSU is where you really have to be careful in. There is high voltage like 400V DC there. Turn the TV on and see what DC V you get on the main filter capacitor. Any voltage you measure in the PRIMARY after the bridge rectifier, the negative of the main filter capacitor is where your negative probe lead goes.
              09-07-2024, 05:50 AM
            • chopduel
              Bad mains power causing TV malfunctions?
              by chopduel
              I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
              Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
              • TV would randomly turn off then back on.
              • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
              • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
              12-29-2024, 03:20 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
