Blank Screen on HV320WXC-200
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Hello.
    I got a blank screen on HV320WXC-200 screen. Im trying to do the jumper method but I don't know how to find the VGH and the other voltages on the side tabs of the screen(COF IC). Does anybody know how to find correctly the test points?
    I have searched the web and I found https://www.amwajsat.net/vb/showthread.php?t=7093 but unfortunately I cannot access the attachments. I created an account but never got the activation email. Can someone help me take a look at the attachments on the first post?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Blank Screen on HV320WXC-200
    OK, ducky29....So you want to attempt a 'by-pass' method screen repair. What do you have and why jump to that conclusion that this repair method is what you need to do? Is the set powering on, are you getting sound and no picture, do you have backlights?
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • Chrissygizmo
      Panasonic TX-48CX350B backlights but white screen , blank screen
      by Chrissygizmo
      Hi all, I’ve got a problem I hope someone can help me fixi.
      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
      01-11-2025, 03:18 PM
    • kotel studios
      Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
      by kotel studios
      Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
      State I got it in:
      Squealing from the PSU
      After logo I get a blank screen
      After 10 seconds of having a blank display w/ backlight the TV dies
      Give it 7-10ish seconds again and it starts to bootloop.
      What I did so far:
      Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
      Checked all voltage rails:
      5VSB - 4.8V
      AMP+13V - 14.4V
      13V - 12.98V (in manual 12V)...
      09-21-2025, 02:00 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • siergiej
      Try to find new screen for ANBERNIC RG 28XX
      by siergiej
      Hello
      I have ANBERNIC RG 28XX small toy but give a lot off joy. But it fell from table and screen break
      Screen is 2.83 inch IPS 640x480 with 39 pin and making YLM-28F1002-A1.
      for several day I try to find this same screen for replacement. So far i'm unable to do it.
      Please help me !!!
      09-08-2024, 02:26 AM
