Samsung UN60EH6000 Tries to come on, but stops
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4342
    • Italy - Milan
    #41
    Re: Samsung UN60EH6000 Tries to come on, but stops
    Sorry, many points that i have pointed at are wrong, this tcon need some tests more and without to measure continuity between points or view datasheets is too much difficult.. i think.. where you measure 12v is much probably not an output but input.
    • karthur
      • Nov 2015
      • 150
      Davi,
      Are you saying the board is just bad and I need to replace the entire board?
      Did I measure at the wrong locations?
      Kirk
      • jetadm123
        • 2169
        #43
        In his video, norcal715 does provide the value of the two capacitors in question: 2.2uf 50v.
        • karthur
          • Nov 2015
          • 150
          Dang, he does @9:40 mark. I remember seeing that when I watched it, but it did not dawn on me what the text was telling me. Good Catch!
          I just checked mine and both of them are shorted. When I measure the physical size of the cap it is 2mm L x 1.3mm W x 1.3mm tall. A quick google search shows this to be a common 0805 form.
          2.2uf @50V Ceramic Capacitor, form 0805 (2012 metric).
          This is the one I found on Mouser. I just ordered 40 of them so I will have a few spares.
          • karthur
            • Nov 2015
            • 150
            Since the two caps are shorted on my board, what are the chances that I replace them and that fixes the board? I guess that depends if the caps are on the output or input side of the ISL9860, which I have no way of knowing.
            I thought it would be worth a shot anyway. I mean, whats the worse thing that could happen.... it pops the caps again?
            • vinceroger69
              • Mar 2012
              • 6714
              #46
              remove the caps and test them it maybe the ic thats causing the shorts your reading
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4342
                • Italy - Milan
                #47
                i mean that i pointed the wrong points to test, 'cause this tcon is a bit confusing to read without datasheet and tester.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4342
                  • Italy - Milan
                  #48
                  I saw now the norcal video, but he tested near 0 volts on that big coil where i've put indications M N, you have the tension he had measured after repair.
                  • nicholas1110
                    • Aug 2012
                    • 127
                    • usa
                    #49
                    I have never had to actually replace the caps on any of these boards that I have repaired. The caps aren’t actually shorted. The ic is. If your remove the ic the short will go away. Testing the caps for a short is just a good way to know if the ic is shorted.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4342
                      • Italy - Milan
                      #50
                      Can't you measure theese points?
                      • karthur
                        • Nov 2015
                        • 150
                        Originally posted by nicholas1110
                        I have never had to actually replace the caps on any of these boards that I have repaired. The caps aren't actually shorted. The ic is. If your remove the ic the short will go away. Testing the caps for a short is just a good way to know if the ic is shorted.
                        I removed the caps in question and they are not shorted. They seem to be good when they are off the board. I replaced them with new ones and the new ones also show to be shorted when mounted.... but I still have the IC in place. Will be replacing it soon.
                        I guess it is like you say ... the ic is actually causing it to show shorted on the caps.
                        Thanks.
                        • karthur
                          • Nov 2015
                          • 150
                          Originally posted by Davi.p
                          Can't you measure these points?
                          Davi,
                          Sorry, I just now saw your post. I will try to get those measurements tonight.
                          • karthur
                            • Nov 2015
                            • 150
                            Davi,
                            Here are the points you asked for.
                            N : 12.7 V
                            O : 11mV
                            P : 1mV
                            Q : 17mV
                            R : 1v
                            S : 1mV
                            T : 12.7V
                            Kirk
                            • Louis82
                              • Feb 2012
                              • 240
                              Hey guys,
                              I have the same issue BUT, I replaced the ISL9860 and picture came back. Tv now plays fine for 15 minutes then picture is gone again. I have to wait like 5 min for picture to come back on but this time it will last 5 min then pictures is gone. Any suggestion ? Should I replaced those caps?
                              My voltage read exactly the same as Norcals Video.
                              Please help!
                                Try running it with the back of the TV open and blown by fan to see if it will run longer.
                                If the caps were to short out then you will not get any video at all, sounds like something heated up and quit.
                                • Louis82
                                  • Feb 2012
                                  • 240
                                  Also, I'm using the thermal or cooling pads on all big IC's before putting the metal plate back on. When I leave the back cover off, tv played fine for hours. Something is getting overheated.
                                  Have this happened to you guys?
                                  • Louis82
                                    • Feb 2012
                                    • 240
                                    Hi budm - Yes it plays fine for hours.
                                      The norcal video said something about adding another heat transfer pad to that power supplies IC.
                                      May be you can add a small 12V fan running off the switched 12V to take the heat away from the T-con to extend the life of the board until it fails completely, SJ has the the alternate replacement that is more reliable.
                                      • Louis82
                                        • Feb 2012
                                        • 240
                                        you mean a thermal pad on the IC ISL9860 i just replaced?
                                        • Louis82
                                          • Feb 2012
                                          • 240
                                          Nevermind budm. Just watched the video again. I will try that next otherwise Im gonna have to buy a new t-con -- great!
                                          • Cornito
                                            Denon AVR-2700H audio stops while receiver still works
                                            by Cornito
                                            Hello team,
                                            I've got a new issue with a Denon Avr-2700H.
                                            After several minutes working, receiver stops playing sound with a poc eared in the speakers.
                                            Receiver still work and display video with error message on display.
                                            Seems to me that is the main output relay.
                                            I'm looking for the service manual that I can't find for the moment.
                                            Does somebody have it?
                                            Regards...
                                            08-03-2025, 06:10 AM
                                          • karthur
                                            Samsung UN60EH6000 Dump
                                            by karthur
                                            I have a Samsung UN60EH6000 that will not turn on. When I turn it on, no start-up melody. Only the screen flickers around the edges. I have replaced the T-con board, but issue persists. I have also checked the voltages on the power board and they seem to be correct.
                                            Power Board: BN44-00500A
                                            T-Con Board: BN95-00944B
                                            Main Board: BN94-05549E
                                            I have pulled off the chip IC901 on the main board. This is a Winbond W25Q128BVFG Chip.
                                            My bin dump is below. Can someone look at this and see if this is good or bad file?
                                            12-16-2023, 02:11 PM
                                          • karthur
                                            Samsung UN60EH6000 wont come on after lightning strike.
                                            by karthur
                                            We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                            I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                            When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                            Here is what I have checked.
                                            On the power supply board, 14pin connector:
                                            1 :12.7 Vdc
                                            3 :12.7
                                            5 :12.7
                                            7 :12.7
                                            9 :0
                                            11 :5.
                                            13 :5....
                                            11-01-2023, 06:18 PM
                                          • 6BW6
                                            Win7 Performance test stops
                                            by 6BW6
                                            I had a dodgy Molex Sata lead go bad that cause crashes once in a while, after repairing all is well with no crashing BUT.... Windows performance test stops. I get-:
                                            Problem signature:
                                            Problem Event Name: APPCRASH
                                            Application Name: WinSAT.exe
                                            Application Version: 6.1.7601.17514
                                            Application Timestamp: 4ce798fc
                                            Fault Module Name: atiuxp64.dll
                                            Fault Module Version: 8.14.1.6463
                                            Fault Module Timestamp: 56254af6
                                            Exception Code: c0000005
                                            Exception Offset: 000000000000dc14
                                            OS Version: 6.1.7601.2.1.0.256.48...
                                            05-29-2023, 04:21 PM
                                          • someonenotyou
                                            Lenovo A485/T480 USB stops working when USB2.0 is plugged.
                                            by someonenotyou
                                            Hi.
                                            I have 2 Lenovo laptops (A485 and T480) with identical USB problem.
                                            When I plug in a USB 3.x device (USB storage), the USB ports are working normal.
                                            But as soon I plug in USB 2.0 device (mouse, USB storage), all the USB ports stop working. Even if I plug in USB 3.x device.
                                            The only way to get USB working again is disconnect battery and reset BIOS.
                                            Has anyone had anything similar?
                                            I have not yet tried another BIOS, but would that be the problem with USB?
                                            Thank you.
                                            03-19-2025, 12:15 PM
