Samsung PS58C7000YM Cycling menus and settings automatically (Video included)
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung PS58C7000YM Cycling menus and settings automatically (Video included)
    so you may need to find a replacement touch sensitive board, im not sure how these are fixed in though but do remember reading a post on this forum a while ago and the touch sensitive board was at fault too.
    • xburger
      • Dec 2017
      • 16
      Is my next step to replace the board or is it something that can be fixed?
      And if I buy a new board, does it generally come with all bits and bobs on it, or will I have to buy those and solder and such? In the pictures I'm seeing it looks like the latter.
      Here are some I have found:
      Open Box City
      TV Parts Today
      ebay
      Shop Jimmy
      I want to thank you both for your help. You've both helped me very much, and I even had a bit of fun.
      I will genuinely buy you both a beer if you give me a payment method.
      • vinceroger69
        • Mar 2012
        • 6714
        its none of those boards you have linked, the wires/connector you have removed and the set now stay on, follow those wires back and see where it goes to and see if theirs a part number on the board as you say its the touch sensitive type so on the other side of that there has too be some sort of board we think thats your fault.
        • xburger
          • Dec 2017
          • 16
          OK. NOW I've found the part. It was silly of me to see the wires run to that corner and assume the E Buffer was the panel I needed. The IR was beneath it.
          Here is the part:
          https://repairpartstv.site/item/2531...l_samsung.html
          • vinceroger69
            • Mar 2012
            • 6714
            Not silly at all if wires went that direction thats why you probably thought that, the main thing now i guess is too see if your board has all the matching numbers etc ive never changed one of these boards so not sure how its fixed too your tv so maybe best to wait and see if more experienced member will advise as these are touch sensitive boards they maybe glued on etc.
            • xburger
              • Dec 2017
              • 16
              That's good advice and the numbers all match.
              Again, thank you very much for your help.
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                I hope you sort it that board is a reasonable price so if it has a return warranty if faulty on arrival maybe worth buying it before they sell out as maybe a common issue its just im not sure how its fixed too the tv itself i guess glue but not sure.
                • attainteddragon
                  • Apr 2013
                  • 764
                  • australia
                  #28
                  they are attached with double sided tape. there are cutouts at each switch, so it does't obstruct the contact point.
                  use a heat gun to warm it prior to removal and you can sometimes remove the board without removing the tape.
                  does this button panel have the ir sensor on it, or is it on a separate board of its own?
                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                  • xburger
                    • Dec 2017
                    • 16
                    That sounds easy enough. I think I may have a heat gun too.
                    The IR sensor is on the same panel.
                    • attainteddragon
                      • Apr 2013
                      • 764
                      • australia
                      #30
                      there is always a chance that it is the ir failing, but if you can replace the board cheap enough, then it may not be worth the time replacing parts on it.
                      remove the entire bezel from the panel to give yourself access to the board for replacement.
                      • int0x13
                        • Nov 2012
                        • 42
                        • France
                        #31
                        Hi, I may have the same issue on a PS42C430. Did you solve the issue by replacing the IR board?
                        • xburger
                          • Dec 2017
                          • 16
                          Yes it did! Its been 5 months now I think and I've been using it just fine
                          Sorry for the late reply.
                          • high-tech
                            Samsung UN55F7050AFXZA ver. TD01 power cycling
                            by high-tech
                            Hello everybody, I could use some help on this one... It's got me guessing...
                            I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                            (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                            (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                            (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                            (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                            9. ground (PWM2) 10. 0.9 volts cycling...
                            09-15-2020, 03:39 PM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            09-06-2024, 06:20 PM
                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
