LG 60pv400-ub stuck in standby mode
  • Sdfoster22
    • Nov 2017
    My TV is an LG 60pv400-ub I got hit in a power surge a while back. All it does when I plug it in is click once and stays in standby mode. It doesn't click or even try to power up when I hit the power button.
    I've done weeks worth of research on how to fix it and I think I've narrowed it down to the main board. Here is what I have tried so far.
    I grabbed a voltage meter. I measured the volts going to the main board. They all checked out. I checked the fuses on the power supply. None of them are blown. I looked at all the caps on resisters throughout the boards and they all seem fine. I removed the power board and main board and inspected them thoroughly and didn't find any burns or blown caps.
    I started unplugging the boards one by one to see which was the problem. All was the same except for when I unplugged the main board. With the main board unplugged the TV comes on and the screen stays lit up but dark, and I noticed the led on the logic board was flashing. There is a slight hum coming from the left side. I tested the vs and va volts with it unplugged and they were spot on. Once I plug the main board back in it does the standby no power thing.
    Does anyone have any suggestions on confirming that the main board is the problem before I commit to buying a new one?
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
