Vertical Lines -- Bad Picture -- LG 60PA6500
  • chood2
    • Oct 2017
    • 11
    Hello everyone!
    I just got done replacing the control logic board on my LG 60PA6500, checking all the caps on my YSUS with an ESR meter, and replacing the Y-Buffer boards.
    https://photos.app.goo.gl/Kock4cX3feFo5os23
    I have these bad spots where the picture is terribly messed up. What do I do?!
  • tw2005
    • Oct 2011
    • 6458
    Re: Vertical Lines -- Bad Picture -- LG 60PA6500
    Originally posted by chood2
    Hello everyone!
    Cry.
    Good chance the panel is faulted on the flexible ribbons at the base, there's a chip embedded which fail or burn out.
    Is this the original fault and why the ctrl bd was replaced? Tried the auto-gen test patterns on the ctrl bd?
    • chood2
      • Oct 2017
      • 11
      Originally posted by tw2005
      Cry.
      The original fault was the "no picture, only sound" issue. Unfortunately, it has evolved into this now...
      • budwich
        • Jul 2015
        • 3097
        check the bottom edge boards on that side... especially where the tabs attach to the boards. Maybe someone "washed" the screen and caused the "initial issue". The connection areas along those boards should be clean / similar. But as was suggested, "crying" might be your only choice... that and selling the boards that you bought / know work.
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • srs
          Insignia NS-50DR620NA18 w/ large vertical lines & no picture
          by srs
          I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
          A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
          I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
          04-22-2023, 02:40 PM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
