LG 55LV9500 no picture wide vertical lines
  • Jtroutt19
    • Aug 2011
    • 164
    Started doing this intermittently until the TV would be on for a few minutes then picture would display. Now it just looks like this regardless.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: LG 55LV9500 no picture wide vertical lines
    take the black heatsink off the mainboard BGA chip and heat it up with a heat gun on LOW for 45 seconds. get all of the chip hot and try not to get anything else. It probably will come back to life, for how long........?
    • Jtroutt19
      • Aug 2011
      • 164
      so you are saying the processor on the main board needs reworked/reflowed. I can take it off and re-ball it. Is there anything else it could be? Would like to rule out less invasive stuff first.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        yes. Re-balling would be the best thing you can do. I have half assed re-flowed 15 of the edgelite led tvs. Only one has gone bad. He had it re-balled somewhere and its fine again. You might want to offer a re-balling service, you would get a lot of work from me and others on B.C.
        • Jtroutt19
          • Aug 2011
          • 164
          never though about offering it. I guess my only issue would I would not be able to verify repair. I would be willing to reball the chip itself and mail back for install to be done by you.
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            let us know how this one turns out.
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • noisykid
              Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
              by noisykid
              5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
              12-30-2024, 07:15 PM
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • hendue
              BenQ 2765HT vertical lines, no picture
              by hendue
              I was trying to fix the monitor, which was giving me the following pictures:
              It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
              I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
              Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
              I turned around...
              09-09-2025, 08:27 AM
            • srs
              Insignia NS-50DR620NA18 w/ large vertical lines & no picture
              by srs
              I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
              A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
              I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
              04-22-2023, 02:40 PM
