Backlight, Sound, No picture, UN75J6300
    I've got no picture, but sound on a UN75J6300, Backlight are clearly working.
    I looked for test points on the Tcon but don't see voltage markings nearby, the service manual was of no help either. No change with Tcon disconnected, main processor heatsink on that board is hot. I understand led driver is part of main board.
    Re: Backlight, Sound, No picture, UN75J6300
    Check the LVDS on the main board with an oscilloscope, while turning on and off the menu of the tv all the time. Check each pair on the LVDS. If you don't see any action, the main board needs to be replaced. If you do see action on the o'scope, the TCon is bad.
    Also: There are 2 ribbon cables from the TCon to the panel. Unhook one of them, turn the TV on and see if you get half of a picture. Then try the other side.
    As usual: PIC's please!
      Get a hires picture of the tcon especially those from shopjimmy site.
        Well I replaced the tcon and no change.
        I also unplugged one ribbon to panel and nothing happened. Screen remained black. Even if the main was bad wouldn't I see something when unplugging one of them?
          Need picture of t-con. Do you have voltage to t-con?
            Is there an FRC card?
              The heat sink is pretty hot on the tcon. Sorry hard to get pics of this beast. There is a small Crack in the top corner,, could that have rendered panel bad!
                Crack in the glass? I think with that crack you must at least see vertical bars..
                  No FRC card on this model. Don't have oscilloscope. I get a bunch of 3.2V readings on the tcon, so I know it's getting something. Even tried manipulating tab bonds to no avail. I guess it's the main. ..
                    The crack is on the panel glass??
                      a crack in the LCD does not make the main board fail.
                        Check 12vin on the tcon.
                          Replaced tcon and main board, still no picture only sound
                            UH01 and TH01 just realized there are two versions of this board. Does it really make a difference?
                              But we still do not know if you have 12V feeding the T-CON board or not.
                                Ok
                                  I'm sorry don't check 12v in, 'cause processor is hot.. even with a crack on a corner you must see at least the other side half. Is there any chip on the panel's boards? Can be at short. You must measure tcon voltages. but whitout a picture i can't point it.
                                    Yes 12v on the fuse both sides. Could melt butter in short order on replacement tcon heatsink as well. Sounds like panel ics.
                                      I think you can't access to the panel's boards due to the size of the screen right? Anyway i think a 75" needs an accurate measurement of the common tensions just to be sure replacement tcon is good, with the heatsink i surely can't point you where to measure..
                                        No, you can get to the panel ics quite easily. Tcon gets hot pretty quick, would it be possible to measure before cooking it?
