Backlight, Sound, No picture, UN75J6300
  • rustytierod
    • Sep 2014
    • 81
    I've got no picture, but sound on a UN75J6300, Backlight are clearly working.
    I looked for test points on the Tcon but don't see voltage markings nearby, the service manual was of no help either. No change with Tcon disconnected, main processor heatsink on that board is hot. I understand led driver is part of main board.
  • CapLeaker
    Leaking Member
    • 8146
    Re: Backlight, Sound, No picture, UN75J6300
    Check the LVDS on the main board with an oscilloscope, while turning on and off the menu of the tv all the time. Check each pair on the LVDS. If you don't see any action, the main board needs to be replaced. If you do see action on the o'scope, the TCon is bad.
    Also: There are 2 ribbon cables from the TCon to the panel. Unhook one of them, turn the TV on and see if you get half of a picture. Then try the other side.
    As usual: PIC's please!
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4318
      • Italy - Milan
      Get a hires picture of the tcon especially those from shopjimmy site.
      • rustytierod
        • Sep 2014
        • 81
        Well I replaced the tcon and no change.
        I also unplugged one ribbon to panel and nothing happened. Screen remained black. Even if the main was bad wouldn't I see something when unplugging one of them?
        • dskall
          • Oct 2016
          • 2905
          • usa
          Need picture of t-con. Do you have voltage to t-con?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4318
            • Italy - Milan
            Is there an FRC card?
            • rustytierod
              • Sep 2014
              • 81
              The heat sink is pretty hot on the tcon. Sorry hard to get pics of this beast. There is a small Crack in the top corner,, could that have rendered panel bad!
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4318
                • Italy - Milan
                Crack in the glass? I think with that crack you must at least see vertical bars..
                • rustytierod
                  • Sep 2014
                  • 81
                  No FRC card on this model. Don't have oscilloscope. I get a bunch of 3.2V readings on the tcon, so I know it's getting something. Even tried manipulating tab bonds to no avail. I guess it's the main. ..
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4318
                    • Italy - Milan
                    The crack is on the panel glass??
                    • CapLeaker
                      Leaking Member
                      • 8146
                      a crack in the LCD does not make the main board fail.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4318
                        • Italy - Milan
                        Check 12vin on the tcon.
                        • rustytierod
                          • Sep 2014
                          • 81
                          Replaced tcon and main board, still no picture only sound
                          • rustytierod
                            • Sep 2014
                            • 81
                            UH01 and TH01 just realized there are two versions of this board. Does it really make a difference?
                              But we still do not know if you have 12V feeding the T-CON board or not.
                              • rustytierod
                                • Sep 2014
                                • 81
                                Ok
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4318
                                  • Italy - Milan
                                  I'm sorry don't check 12v in, 'cause processor is hot.. even with a crack on a corner you must see at least the other side half. Is there any chip on the panel's boards? Can be at short. You must measure tcon voltages. but whitout a picture i can't point it.
                                  • rustytierod
                                    • Sep 2014
                                    • 81
                                    Yes 12v on the fuse both sides. Could melt butter in short order on replacement tcon heatsink as well. Sounds like panel ics.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4318
                                      • Italy - Milan
                                      I think you can't access to the panel's boards due to the size of the screen right? Anyway i think a 75" needs an accurate measurement of the common tensions just to be sure replacement tcon is good, with the heatsink i surely can't point you where to measure..
                                      • rustytierod
                                        • Sep 2014
                                        • 81
                                        No, you can get to the panel ics quite easily. Tcon gets hot pretty quick, would it be possible to measure before cooking it?
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • ronni
                                          Sony KD-43XE8005 with sound, backlight, no picture
                                          by ronni
                                          I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                                          When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                                          Removing the LVDS cable results in...
                                          12-01-2022, 08:44 AM
