Toshiba 32" regza 32AV615DB rolling horizontal colour bars
  • brokentvguy
    • Oct 2017
    • 6
    • england
    I have a Toshiba 32" regza tv, model 32AV615DB, when i switch on from cold i get horizontal rolling colour bars, audio is ok you can hear the station, when the tv as been on for around 10 to 15 minutes and warmed up the picture comes clear and stays good, if you switch off then back on the picture comes on straight away, the problem only occurs from switch on when cold.
    I took the back off the tv last night, i couldn't see any bulging capacitors, there were two 1000uf/35v caps on the power supply/inverter board that didn't look totaly flat more inwards dent than outward so i removed these and tested them 968uf and 970uf so put them back in.
    I disconnected all the removable plugs then reconnected them to see if there was bad connection, problem still present.
    I took a couple of photos of the problem on switch on, new to tv repair so any guidance very welcome.....thanks Jack
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Toshiba 32" regza 32AV615DB rolling horizontal colour bars
    maybe try heating each board up in turn with a hair drier, as the heat should make the fault clear up quicker, then you can narrow down the board at fault it could possibly the lcd panel i guess try heating and see if you get results.
    • brokentvguy
      • Oct 2017
      • 6
      • england
      Thanks for the hair drier tip, I warmed each of the boards up with an hair drier, when i heated the power supply board up the picture was clear within around a minute of applying heat, so thought it was the two 1000uf caps i'd already tested so ordered replacements, the two new caps didn't fix the fault.
      I tested the output voltages of the power supply board 5v, 12v and 24v all tested good, is there anything else i can do to try and fix the problem.
      • vinceroger69
        • Mar 2012
        • 6714
        so heat on the power board does make the issue clear up maybe now narrow the area your heating more i use a cardboard tube and aim the heat down it that way you can single out parts
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          +1
          You need to keep narrowing down the area you are heating up to locate the fault as suggested by vinceroger69
          • vinceroger69
            • Mar 2012
            • 6714
            may also be a surface mount part on the underside of the psu in that area your heating up.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Some clear photo's of your boards could prove useful not having the set here at hand.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4464
                • Italy - Milan
                "may also be a surface mount part on the underside of the psu in that area your heating up." But what do you say? A faulty chip or anything little and smd can't get better with heat... To the OP, change all the El. capacitors on the power board, except the 450v ones, that are difficult to find, and use low impedance/esr types (only good brands).
                • x_orange90_x
                  Samsung UN46C8000XFXZA vertical bars/horizontal lines
                  by x_orange90_x
                  I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                  The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                  09-04-2023, 12:09 PM
                • CapLeaker
                  LG 65UQ70 horizontal bars jumping
                  by CapLeaker
                  So I bought this LG 65UQ70 today at Walliworld. Put the wall mount on, set it up, worked for 30 mins and then I get these jumping horizontal bars. Let the TV do updates and let it cool down for 5 mins. Worked perfect for 2 mins. As soon the TV is warm I get the jumping vertical bars again.
                  Keep the other TCL thread in mind. Now I am questioning are all COVID 2022 / 23 TV’s bad or what? That’s two 65” TV’s one from Amazon and this one from Walmart. What are the chances on that?
                  I guess this one goes back either later today or tomorrow morning, unless...
                  08-13-2024, 09:41 AM
                • Akira81
                  LG 55LF652V-ZA flashing led bars despite their replacement
                  by Akira81
                  I have this 55" LG 55LF652V-ZA smart TV which suddenly started flashing intermittently every 2 seconds with the backlight.
                  If I aimed the light bulb of my cell phone I could see the underlying image even in those fractions of time when the LEDs were off and the audio instead came out continuously.
                  Armed with a lot of space and patience, I decided to open the TV, immediately noticing that a LED had flamed out and also burned a portion of that reflective white panel behind the transparent LED diffusers.
                  04-14-2023, 11:50 AM
                • Ihandyrepair
                  Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                  by Ihandyrepair
                  Hi guys
                  I just started fixing 4k TV few months ago. so I am still learning a lot
                  I got this tv from friend complaint is ghosting or horizontal lines on image.
                  never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                  then it started to show the ghosting white image.
                  I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                  it has 3 thin small boards at the bottom of the...
                  12-05-2022, 04:18 PM
                • kotel studios
                  Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                  by kotel studios
                  Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                  In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                  08-06-2025, 02:07 AM
