Vizio M501i-B1 - Tries to turn on over and over but can't.
  • Cam.anderson22
    • Oct 2017
    So I've done quite a bit of research on vizio's not having power or not turning on. I haven't found anyone with my specific problem yet. It tries to turn on over and over again, but it never fully boots up. The white led on the bezel comes on and then dims out, and the red/blue led comes on on the main board. This repeats every 45 seconds or so. It finally came on in the middle of the night after about a week of this cycle, but now I can't get it back on again. None of the caps seem bulged either.
    Power supply Model 715G6100-P04-003-002H.
    Main Board Model: 715G6815-M02-000-005N.
    I've metered the voltages coming out of the power supply, and I get what should be expected.
    19.74v on hot rails
    5v good
    12v good
    24v is 19.74v
    PSON is 3v
    Dim is 3v
    On/Off is 0.06v when trying to turn on, 0v on standby
    Large caps at bottom of board are at 393v
    Question is, which board should I replace? Does this sound like a main board or a PSU problem?
    Thanks in advance!
    Pic of the back of the tv
    https://drive.google.com/open?id=1r9...KlVODJIg1GNjRA
    Re: Vizio M501i-B1 - Tries to turn on over and over but can't.
    The main board is not sending the BL-ON (ON/OFF) to turn the backlights.
    Are you sure that getting 19.74V instead of 24V?
    • Cam.anderson22
      • Oct 2017
      Yes, 19.74v going to MB and LED driver board.
      • Cam.anderson22
        • Oct 2017
        Any ideas? There's a multi wire going from the MB to the led driver board, and only one pin has voltage on it (12v). All the other pins are zero.
          "On/Off is 0.06v when trying to turn on, 0v on standby"
          Right now the main board is not sending the ON Voltage to turn on the backlights circuit.
          You may be able to simulate the ON/OFF signal by using the 1000 Ohms resistor between the STBY 5V and the ON/OFF pin, BUT YOU MUST DISCONNECT this wire going back to the main board first.
          • Mulp
            VIZIO M65-C1 Does Not Turn On
            by Mulp
            Hi All,
            I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
            When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
            I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
            01-13-2024, 09:57 PM
          • pajdek
            Lenovo Y700-17ISK turn on and off
            by pajdek
            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
            09-20-2023, 02:49 AM
          • RdeveLabs
            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
            by RdeveLabs
            To all the members here...
            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
            05-05-2025, 04:59 AM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • robante15
            Acer Aspire 4520 won't turn on after reboot
            by robante15
            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
            If I remove the...
            04-06-2024, 06:50 PM
