Samsung LE32B350F1W BackLight problem
  • HellasTechn1
    • Sep 2015
    • 176
    • Greece
    Hello everyone !
    I am back with a new riddle for us to solve.
    Ihave this Samsung LE32B350F1W television that a colleague brought to me to either fix it or scrap it.
    This tv set will turn on "can hear the turn on sound" but the backlight will turn on for one secod and then turn off. The tv remains in the on state.
    At first i thought that it could be a bad ccfl lamp so i removed the power board and with my ccfl tester i have turned on all four ccfl lamps and turns out they are all good.
    The psu is this one BN44-00289A
    I measured voltage across the main filter cap and i get 350V dc. That is pretty low as far as i remember. Should be around 380 or more with TV turned on right ?
    So could anyone guide me what to do next ?
    Could it be a bad PFC chip ? i dont have a replacement for that right now...
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung LE32B350F1W BackLight problem
    maybe worth a read of this thread as its the same psu and has a link too the schematic also maybe worth you checking the resistance on the invertor transformer winding's
    https://www.badcaps.net/forum/showthread.php?t=25196
    • dskall
      • Oct 2016
      • 2905
      • usa
      There should be feedback resistors on your pfc chip. Make sure they are reading correct
      • HellasTechn1
        • Sep 2015
        • 176
        • Greece
        Thank you I will.
        To be honest i have no idea what to measure. Could you please guide me further ?
          https://www.badcaps.net/forum/attach...4&d=1356896986
          Check the PFC diode DP802 (?) to make sure it is not shorted or has bad leakage resistance.
          • vinceroger69
            • Mar 2012
            • 6714
            just found the specs on the invertor transformer, The secondary resistance is about 1.0K between S1 and S2(S3 and S4). The primary resistance is about 0.3 ohm between P1 and P2.
            • HellasTechn1
              • Sep 2015
              • 176
              • Greece
              The Dp802 removed from the circuit (by removing the jumper smd's) on my DMM set to diode test, reads 0 reverse biased and forward biased would slowly rise up to 0.513 - 0.515.
              I also get strange readings from ZDI802.With DMM set to diode test, when on circuit it will read 0.032 both forward and reverse biased.
              When removed it reads 0.692 forward biased and 0 reverse biased
              for the zener by forward biase i mean (negative off dmm to stripe on body and positive to other side). when removed i read no short accross its pads.
              P.S. i am going to replace it anyway since i happen to have one and i will see what happens. Though i suspect it is the rest of the circuit that produces the weird readings.
              • HellasTechn1
                • Sep 2015
                • 176
                • Greece
                I replaced DP802 and the problem is still there.
                I noticed thogh that Voltage across the main filter capacitor now when TV is on, is 383Vdc
                and when off, it goes down to 310.
                I will report the otuput readings of the PSU because i think they are slightly low.
                CN802
                PIN No.-------DESCRIPTION--------------DMM READING
                16.----------------GND
                15.----------------GND
                14.--------------DET_5V-----------------------3,01V
                13.---------------E-PWM-----------------------5,05V
                12.----------INVERTER ON/OFF--------------12,95V
                11.----------------13V------------------------12,95V
                10.----------------13V------------------------12,95V
                9.-----------------GND
                8.------------------5,3V------------------------5,17V
                7.------------------5,3V------------------------5,17V
                6.------------------GND
                5.------------------GND
                4.------------------13V------------------------12,95V
                3.------------------GND
                2.------------------5,3V-------------------------5,17V
                1.-----------POWER ON/OFF-------------------2,15V
                So DET_5V is way out and 5.3V also not good. I am not sure about power on/off pin, i think that should be 3.3
                • vinceroger69
                  • Mar 2012
                  • 6714
                  disconnect CN802 that goes to the main board (this will force the PS_ON and BL_ON line to go HI, if the board is OK, the backlights should turns on when you plug the TV into the AC outlet.
                  • HellasTechn1
                    • Sep 2015
                    • 176
                    • Greece
                    Good advice, Though i have already tried that and with mainboard disconnected, backlight comes on for a second and goes off again. Same symptom. That indicates a bad PSU.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      did you measure the invertor transformer windings?
                      • HellasTechn1
                        • Sep 2015
                        • 176
                        • Greece
                        Yes, i forgot to mention that. 1kohm each secondary winding and 0.something on primary windings of both transformers. So they are good.
                        To be honest i think a bad transformer is rarely the case.
                        • HellasTechn1
                          • Sep 2015
                          • 176
                          • Greece
                          I think that the low voltage on DET_5V suggest problem with inverter or lamps... Thats probably why lamps go off but again how can i say for sure... Is there a way to test the CCFL controller chip ?
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            if you read that other thread i linked im sure it tells you how too test the controller ic or disable the det line
                              DET_5V should be <1V when TV is in standby and it should be >2.5V when the inverter circuit is running.
                                CN802
                                So now the PFC Voltage is correct. Does it stay at that level when the backlights come on?
                                Det_5V is just the error signal, LOW = <1V, HIGH = > 2.5V.
                                That 12.95VDC control signal cannot be right, it cannot be that high.
                                • HellasTechn1
                                  • Sep 2015
                                  • 176
                                  • Greece
                                  I am performing new measurements as we speak. posting back in a minute.
                                  • HellasTechn1
                                    • Sep 2015
                                    • 176
                                    • Greece
                                    I wrote down the readings wrong....
                                    DET_5V = -0.009V
                                    E-PWM = 3.01V
                                    INVERTER ON/OFF = 5V
                                    My mistake was that i counted down from after pin 16 but i forgot that the first gnd pin was the one i had the test lead on ! how dum i am...
                                    I can confirm that the main filter cap has a stable 383Vdc before and after ccfl shutdown.
                                    also i have tested all diodes i could find and found none shorted. I have tested most smt diodes also and are good also. the tl431 vregs are also good.
                                    • HellasTechn1
                                      • Sep 2015
                                      • 176
                                      • Greece
                                      Now this is interesting !
                                      i was looking at the OZ9938 datasheet and i thought to myself, why dont i try to disable protection just to see if the ccfl's will keep on !
                                      So i shorted pin 3 between the resistor and the capacitor to pin 16 and it worked.
                                      The ccfl's winn not go off.
                                      That confuses me further because the lamps are good, i have tested them one by one with a ccfl tester and they are all glowing.
                                      • HellasTechn1
                                        • Sep 2015
                                        • 176
                                        • Greece
                                        I have tested the ccfl's again one by one and found out that one of them is running a little noisy... Yesterday when i tested them the room was not that quiet so i could not hear it. I will dissasemble the panel later and replace it to see what happens.
                                        • fanaticgames
                                          Samsung UE32D4010 Backlight problem, led ok
                                          by fanaticgames
                                          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                          02-22-2023, 09:46 AM
                                          09-07-2024, 05:50 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • sandinemail@hotmail.com
                                          Samsung BN44-00284A Backlight problem
                                          by sandinemail@hotmail.com
                                          Samsung BN44-00284A in a Samsung LE40B755 TV bought 2009.
                                          In November 2020 the TV didnยดt turn on only flashing red diod on front off TV.
                                          I then opened up the TV and found bulged capacitors on the inverter/powerboard.
                                          I changed all capacitors except the main two 450V 100uf capacitors.
                                          The TV has worked pefectly since.
                                          But this week it started to turn off the backlight. Audio on TV still works.
                                          Sometimes it turn off the backlight after 10 seconds but sometimes it works for hours.
                                          Any suggestions on what might...
                                          02-15-2023, 05:10 AM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
