On/Off-cycling of Samsung-Plasma-Mainboard(BN94-03354G) repairable?
  • amoll
    • Apr 2017
    • 9
    • Austria
    Hello everybody,
    I have a Samsung-Plasma-TV(PS42C430A1W) which doesn't turn on and a relay on the powerboard is clicking on/off endlessly.
    I removed the mainboard(BN94-03354G) and connected the test-switch(pin 3 and 4) with jumper on the t-con-board and the tv turned on and showed images.
    So I think I do have a defective mainboard.
    Before I order a new board, I want to ask if somebody has an idea which component on the mainboard could be damaged? Where can I spot for errors??? I have no clue...
    In another thread about a different samsung-tv-model with same error pattern. I read, that on that TV a capacitor(C102) is the cause for power-cycling. Sadly on my model I don't have this capacitor?!
    I would really appreciate if anybody has an idea where and what makes sense to measure to find the defect...
    thanks!
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: On/Off-cycling of Samsung-Plasma-Mainboard(BN94-03354G) repairable?
    not sure how those work but i just fixed a samsung lcd tv with same symtoms and it was the eeprom corrupted . i reset it and now its fine . sometimes the eeprom needs changing .
    the problem started with bad capacitors on the power board so needed changing first .
    not saying it will fix yours .
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Normally when you disconnect the mainboard from the control board and jumper the test point 3 & 4 and the test patterns are displayed without any issues that normally points to a defective mainboard
      • amoll
        • Apr 2017
        • 9
        • Austria
        Did some further investigations and it seems that I have a short somewhere.
        Perhaps one or both of the SMDs-Caps may have gone bad or the voltage regulator(s)???
        The chip on top is a buck-regulator(AOZ1021) and the output voltage pin to ground measures only 14.5 ohms.
        The diode next to it measures in diode mode 2.9v in reverse. In the other direction it seems to be correct.
        Seems all a bit strange to me, but I don't know if all of these are gone bad or only one component.
        Any hints?
        Thanks!
        • amoll
          • Apr 2017
          • 9
          • Austria
          There is another buck converter AOZ1031AI on the board where pin 1(PGND) and pin 8(LX) measures 0.3 ohms...
          Any idea which components most likely short out on these boards?
          Visually everything looks fine...
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Can you lift the capacitors and see if the short goes?
            • amoll
              • Apr 2017
              • 9
              • Austria
              I pretty removed everything from the top side and the short didn't go away. Then I flipped the board and removed roughly pretty much on the bottom. Finally short away...and board away!
              I have to buy a new one and finally still don't know what went wrong.
              If anybody has same problem in the future, perhaps better focus on the back side...
              Sorry for not being wiser now and thank you for your help!
              • heavymachines
                • Mar 2011
                • 1028
                Yikes... Not quite enough heat removing the bga chips, looks like damaged pads.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  maybe if you could of found what line was short you could of injected voltage with a low amps and seen what gets hot etc it usually shows shorted smd parts etc
                  • amoll
                    • Apr 2017
                    • 9
                    • Austria
                    Yes, I know, I was impatient and the board was trash anyway...and I hardly desolder bga-chips usually...actually, I think it was my first...
                    Oh yes, that sounds like a very good idea!!! I keep that in mind for another time. Thank you for the hint!
                    • Mirenia
                      Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                      by Mirenia
                      I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                      I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                      In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                      The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                      03-30-2025, 06:47 AM
                    • MMH3
                      Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                      by MMH3
                      i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                      Never ever i experienced problems with that.
                      Now i have one 5050sff machine, where this jumper isnt working at all.
                      I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                      The history of the machine is that i used it in my office...
                      03-23-2025, 09:28 PM
                    • orcic
                      MASTER TL240 and new mainboard LW36BKC01
                      by orcic
                      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                      Now I have some doubts about how to connect the new mainboard to the old power supply.
                      First of...
                      05-12-2023, 08:10 AM
                    • Devonavar
                      Vizio M43-C1 - How closely do I need to match the mainboard number?
                      by Devonavar
                      I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                      I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                      Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                      So, I've ruled out the PSU for now.
                      The reboot loop...
                      08-14-2022, 08:46 PM
                    • Malva
                      Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                      by Malva
                      I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                      Mainboard model: EAX65684604
                      PCB marking: EBT62954607
                      SPI chip: Winbond W25X20CLNIG Problem description:
                      Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                      After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                      • I bought another
                      06-25-2025, 02:07 PM
