Skyworth 40E58 no display
  • yobbgsm
    • May 2017
    • 63
    Hi Experts,
    I have a here, a 40" LED TV brand is skyworth, I thought it was a backlight issue since I can see a display using a torch. Voltage are good up to 37V output to LED. I opened it up and test all the backlight to find out nothing is busted. All are good. I rehot the TPS61196 Led dirver IC, assembled and test, seeing dispaly and I even the set the backlight but after closing the unit and boot up again, same issue occur, ni display again likeno backlight. Do you think the Led driver IC is the culprit? Voltage are good to the backlight. Any idea is very much appreciated.
    Pics attached of the board.
    Re: Skyworth 40E58 no display
    It looks like the boost converter is not working, I expect more than 37 Volt.
    Put the meter probes on the two legs of either one of those tow lytics cap (CP2, CP3: 100uf 100VDC) laying on its side then turn the TV on to see how high it goes up too and then wait 5 seconds to see how low it goes down too; then remove the LED connector and do the same test and report the results.
    • yobbgsm
      • May 2017
      • 63
      Hi budm,
      Your always helpful, appreciate it. So I followed your instructions and got these results.
      Caps- 55V high then went down to 30V.
      Same result on the LED connector. Do you think there is an issue on the voltage?
      Thank you so much!
      • yobbgsm
        • May 2017
        • 63
        Do you guys have a schematic diagram for this model? Thanks.
          OK, at least the Voltage Boost converter did kick on for seconds,
          Next thing you need to do is to test the Voltage on all 6 wires (6 wires are what I can see) at the LED connector (connector in place).
          Start by leaving the TV off and leave Black meter probe on the chassis, then put red probe on one of the 6 wire and then turn on the TV while looking at the meter to see how high the Voltage go up to, record that reading and then turn off the TV.
          Repeat the same procedure on the other 5 wires and report your finding.
          https://www.badcaps.net/forum/attach...4&d=1508126628
          BTW, I can see that the LED connector has the pin labels for each pin but I can hardly see it.
          • yobbgsm
            • May 2017
            • 63
            @budm
            Will do and post result. Thank you for your patience.
            • yobbgsm
              • May 2017
              • 63
              This can be close. I resolved the issue, there is a single bulb that I think soon to be busted. It's on and off the reason there is a display sometimes.
                When you finished the repair, make sure to turn down the Backlights level (not Brightness) to as low as possible to extend the life of the LEDs, these LED backlights are pushed to the limit so they burn out after a few years or less.
                • heavymachines
                  • Mar 2011
                  • 1028
                  Thats what i did with the samsung we fixed yesterday the backlight setting was maxed out!!!! No wonder why it killed the bulb i replaced. and probably why it wanted to shut down on the replacement.
                  • autovolt007
                    • Nov 2017
                    • Philippines
                    Originally posted by yobbgsm
                    Hi Experts,
                    sir i need a little help here, since you have that same board can you please take a look at the number of the smd transistor at the QP5 near opto? i got the same board and mine is bloated so i cannot see the number. this will be a very big help sir. thank you
                    • autovolt007
                      • Nov 2017
                      • Philippines
                      this is my board sir skyworth 40e58, anyone here with a board like this i need a little help that one pointed in red arrow what is the number of it? thanks in advance
                      • signal.quest
                        Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                        by signal.quest
                        I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                        03-17-2024, 10:14 AM
                      • lanovey
                        SF314-41 BIOS without internal display
                        by lanovey
                        Hello there,
                        I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
                        I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
                        06-13-2025, 02:38 AM
                      • dbuergi
                        Acer XF240Y display backlight on and off then stays on but no display
                        by dbuergi
                        my display shows some strange bevahior. The backlight turns on, off and then stays on but i get no display or Acers logo. After some time it goes into standby. My notebook identifys the screen when i connect it by HDMI but i don't get an image.
                        Voltages seem n​ormal and the only possible problem i found is the cap on C33 on the tcom board. It shows 0 Ohm and 0V in diode testing. Any ideas for next steps or what i can check?...
                        11-14-2024, 04:36 AM
                      • MtapeK
                        820-01041-A Without BOTH internal display, And External and Backlight.
                        by MtapeK
                        Hello I have an 820-01041-A that does not have BOTH display and Backlight. The MBP was working properly to wake up without Display overnight. I have Tried SMC and NVRAM reset they both are not solving my Problem. The CapsLock on the KeyBoard, is working when you power it ON, and when you plug the Charger it's Responding with a sound that signifies the MBP has BOOTED in to SYSTEM. I have tried an HDMI (external Screen) its NOT Displaying anything. Also the INTERNAL Display Shows nothing.
                        1. I have Changed U9850 and the results are still the same, Discovered that the IC is working on a Good Known
                        07-30-2024, 08:13 AM
