UE40D5500 random reboots
  • mikkhh
    • Jun 2016
    • 13
    • Estonia
    The Samsung UE40D5500 reboots after 2-5minutes (turns off for a second and then boots up). To me it seems like it can be psu LED protection circuitry issue most likely or somekind of mainboard fault (tv has the neeest firmware, but maybe eeprom or nand chips are playing tricks). Before I remove all led protection I am looking for guidamce about the repair and what could be the real cause and whether or not my assumptions are correct.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: UE40D5500 random reboots
    Can you post photo's and voltage readings you have taken.
    • mikkhh
      • Jun 2016
      • 13
      • Estonia
      Voltages are correct, the reboot interval is fixed ( gets shorter when the tv gets hot). It is the mainboard fault...
      • Psychedelic
        Corsair AX850 low 12v and 5v voltage with random reboots.
        by Psychedelic
        Hi guys,
        I am having problems with an Corsair AX850 Gold PSU. I have had the PSU FOR around 8 years but it had not been used much. This PSU was used to power two video card and an i7 CPU originally. I noticed that the 12v power was going as low as 11.4v and the 5v was going lower than 5%. I was getting random reboots. I found that the motherboard socket had bent pins and one actually broke. Therefore, I assumed that was the problem and not the PSU. I rebuilt a whole new system. This time AMD. I decided to use this PSU since I had it.
        Now with the new system I am still...
        02-17-2021, 06:19 PM
      • Prosatanosz
        Asus B85M-GAMER no hdmi output and random restarts
        by Prosatanosz
        Hi!
        Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
        10-19-2024, 05:27 AM
      • Dreigas
        Asus TUF Gaming FX506LX laptop just stuck at random time
        by Dreigas
        I've got a problem with my Asus TUF Gaming FX506LX laptop. I bought it as a non-working unit it had been completely drenched in a sweet alcoholic drink and was left for a year... When I got it, the motherboard wasn't in terrible shape, but I had to clean a lot of areasβ€”about 1/5 of the motherboard. There was some corrosion, but I managed to clean it up and re-soldered where I saw issues under a microscope.
        One of the two primary MOSFETs was fried (PQ33 fried and PQ34 were fine), so while I was waiting for a replacement, I desoldered it and created a short....
        07-27-2024, 05:58 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • alambrose
        LG GRAM random bsod SOLVED
        by alambrose
        LG Gram 15Z980 picked up on Ebay for $200 (was sold as parts because no M2 drive and bios pw locked), but otherwise intact and working.
        Threw a 500gb M2 in, and was able to install Windows. On Gram, Win activation is stored in the bios, so Windows was automatically activated. I still kept getting random bsod's. Also bought a pw and unlocked the bios.
        Upgraded Windows to 11, still didn't solve the random & frequent bsod's. Cleaned & reseated all cables, RAM, etc... still getting frequent bsod's. Bought & installed a new stick of RAM, still getting frequent...
        02-12-2023, 06:12 PM
