panasonic tc-p50s60 bricked after firmware update?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: panasonic tc-p50s60 bricked after firmware update?
    Why did you originally update the f/w in the first place?
    --What faults indicated to you to go to that extreme?
    Regardless of what makers say, when updating f/w there's always a possibility of bricking it--no matter what the thing is, let alone TV sets with their multitude of different versions--Of the same set!
    Route of last resort in my book, leave f/w alone unless you know for sure its the cause of the problem, and if there IS NO Problem, defo dont do it--don't even think about it!
    TELEFIX
    • mushchampion
      • Oct 2017
      • 17
      Originally posted by Moreno83
      Can you take a clear picture of the SC board? Especially the bottom left area , is there a SC50 jumper? ( between 2 white connectors )
      If so , remove the 2 buffer boards or make sure they DONT touch the sc board. Use a harddisk jumper or something else and short the 2 pins. Turn on the tv and see if it stays on.
      What it does is turning on the tv without sending a image to the panel. If it stays on you got bad buffer boards.
      If the 6 blink error stays on BOTH sc boards your problem seems to be the mainboard. I will look in the service manual when i get home.
      Let me know what the outcome is!
      I found an old hard drive jumper and wedged it into the SC50 jumper (it wasn't easy to get the jumper in there, like it was just a little bit too big)
      The result was the same 6 blinks. I haven't tried my original SC board yet, that's next. (edit: I put the original SC board back in, with the jumper, and got the same 6 blinks)
      If the TV Stays on with no signal being sent from the buffer boards.... how will I know? Will I be able to pull up the onscreen menus and such?
      • mushchampion
        • Oct 2017
        • 17
        It was a silly reason, that I deeply regret now that I've possibly bricked the TV. I was having trouble getting the TV to recognize my network's media server, and figured updating the firmware couldn't hurt.
        That being said, for most of the time I've owned this TV, I haven't even had the internet options turned on. I had a roku3/cable box/pc all hooked up to this TV through an Onkyo receiver so I never really ever used the few built in apps/features that this early smartTV has... I was wanting to move the roku to a different room with an older TV.
        • heavymachines
          • Mar 2011
          • 1028
          Think you're gonna need one of these and flash original back.
          https://www.ebay.com/itm/USB-BIOS-EE...ss!49457!US!-1
          • mushchampion
            • Oct 2017
            • 17
            Since I have two A-Boards, wouldn't it be possible to just swap the chip from the "new" board I got into the old one that I know is bricked? If the new A-Board I received is indeed faulty, perhaps the one part (an IC?) I need from it isn't? Since I would most likely have to source the bin from the new board I got anyway(I don't know how easy it would be to find online), would it be easier to just swap the ICs?
            Looking at these boards, none of these chips look removable, at least not for a novice like me - but if an IC swap on the main boards seems like a plausible solution, I could bring the boards to a local professional to do it for me.
            I appreciate everyone's help and suggestions in this thread, getting into the EEPROMs and Integrated Circuits and going down to that level has me a little overwhelmed, and is a rabbit hole of research to understand all of it.
            • heavymachines
              • Mar 2011
              • 1028
              if they're indeed same exact board yes it is possible, but it would make more sense to copy the bin from it and transfer it to the other rather than butcher possibly good board, but then again we don't know if it's rom er bin is corrupted or not which may very well be the reason replacement not working.
              • heavymachines
                • Mar 2011
                • 1028
                http://www.shopjimmy.com/panasonic-t...-tc-p50s60.htm
                Is that same as yours part number and all? i'll see if i can find you an A board
                • heavymachines
                  • Mar 2011
                  • 1028
                  yeah it is found this one and will work have yet to get anything bunk from them.
                  http://www.tvpartstoday.com/TXN-A1US...sh-a1usuus.htm
                  Little pricey but will stop the woes, get a refund on the bunk one.
                  • mushchampion
                    • Oct 2017
                    • 17
                    That's where I got the new A-Board in the first place, it was the last one in their stock when I ordered it a couple weeks ago.
                    You have to call them to set up a return, I might do that tomorrow or at least see if they will exchange the A-Board I purchased for the one they have in stock now.
                    • heavymachines
                      • Mar 2011
                      • 1028
                      They should take care of you, as i have yet to get anything junk yet from them but it is possible.
                      • mallard729
                        p65 c1 bricked during auto firmware update (need rom)
                        by mallard729
                        Hey all
                        So my rock solid p65 (lol) got stuck with a auto firmware update stuck at 20% for a few hours, finally had to hold down power button, tv is now in the logo reboot loop, cycles about every 25 seconds. the buttons on the back of the tv do not seem to function, i tried loading firmware with no luck... nothing is recognized.
                        in my course of research i think that the eeprom u202 got corrupt during the failed update, i have reached out to vizio, but not hopeful as tv is long out of warranty. Wonder if vizio would at least send me the .bin file for the u202 chip
                        I have been...
                        12-13-2021, 01:33 PM
                      • codernov
                        soundboks 3 bricked firmware ($600 bluetooth speaker)
                        by codernov
                        https://i.ibb.co/Z1hKTkwW/0001.jpg
                        https://i.ibb.co/BK7YmhHx/2025-06-06-16-14-IMG-5818.jpg
                        This thing is pretty expensive. More than an average notebook.
                        Anyway. I got this job over facebook market place. Customer said he bought it used and it was working fine, then he decided to upgrade firmware and somewhere along the way the battery died or whatever we don't know, it got bricked. That's his story and he's sticking with it.
                        If we connect power supply to it, we are getting 21 milliamps and nothing is happening. Pressing buttons does nothing....
                        06-06-2025, 07:05 PM
                      • TheUser
                        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                        by TheUser
                        Hello to everyone ,
                        This is my first post here, and i would like to share with you a small story in case you can help me.
                        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                        02-10-2024, 02:07 PM
                      • rumpumpel1
                        ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
                        by rumpumpel1
                        Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
                        10-24-2024, 08:59 AM
                      • dkneyle
                        Sony KDL-46HX850 Can't upgrade/update firmware
                        by dkneyle
                        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                        09-25-2024, 10:44 PM
