Samsung LN52A650A1FXZA dead, standby LED just flashes repeatedly
  • kevinm34232
    • May 2012
    • 1884
    As stated above it just flashes the red standby light every 2 seconds repeatedly, nothing else. Inspection of the PS board shows very high heat in the section to the left of the large caps between the heat sinks. Nothing obvious shorted. The large cap'(s) voltage is fluctuating from about 190v-220v while standby light flashes.
    Any ideas where to start with this one? Thank you.
  • CapLeaker
    Leaking Member
    • 8177
    Re: Samsung LN52A650A1FXZA dead, standby LED just flashes repeatedly
    Sounds like this:
    https://www.badcaps.net/forum/showth...hlight=samsung
    Can you give a exact description on what your tv is doing or not doing?
    • kevinm34232
      • May 2012
      • 1884
      It looks like there's a short on the main board, the 5V line.. I jumped the PS-ON and everything is good there. Haven't made any progress trying to find the short though.
      I've tried freezing components but no luck there as it doesn't stay on long enough to get hot, and same with an external PS.. Any ideas?
      • kevinm34232
        • May 2012
        • 1884
        Found the short on the B5V line but unfortunately did not fix the TV, all voltages present but TV does not turn on, no inverter_On from main board. Relay clicks every 40 secs. Thinking main CPU is bad.
        • dskall
          • Oct 2016
          • 2905
          • usa
          What is voltage between legs of main cap in standby and when you press power button
          • kevinm34232
            • May 2012
            • 1884
            When you first plug in you get 163V at caps for a couple secs, relay clicks and PS turns on, voltage now 390V. It will stay here for 40 secs and repeat cycle. Power button does nothing. This is common with these models with a faulty main board, I've seen many and not found a fault so I've chalked it up to the CPU.
            • CapLeaker
              Leaking Member
              • 8177
              Me too
              • kevinm34232
                • May 2012
                • 1884
                For what it's worth, the shorted component was either C115 or C903. I took them both off at once so not sure which one it was.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  So the fluctuating voltage of 190v-220v was not on main caps?
                  • kevinm34232
                    • May 2012
                    • 1884
                    That was before finding the shorted SMD cap on main board. ^^^^
                    • kevinm34232
                      • May 2012
                      • 1884
                      Can't resist the curiosity... Got a working board and tested the differences in voltages in this area.. Noticeably a problem between the 3.3v and 1.7v voltage regulators (see circled). Input/output on good one should be 3.3v/1.7v, but bad board is showing 2.5v/1.4v.
                      Is this worth trying to chase down? Every once in a while I see a quick backlight flash like it's trying to power on but then nothing..
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        Does the regulator get hot? Might trace back your 3.3v. May have problem on 3.3v line
                        • attainteddragon
                          • Apr 2013
                          • 764
                          • australia
                          you could lift it off of the board and see if your 3.3v comes back up.
                          WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                          • kevinm34232
                            • May 2012
                            • 1884
                            No it's not getting hot.. But does the other regulator 5>3.3v feeding the 3.3v to this one? If so there is a breakdown somewhere in that line unless it's being pulled down on the 1.7V line? Is that likely?
                            • kevinm34232
                              • May 2012
                              • 1884
                              That was my ? basically, so lift the 3.3V>1.7 regulator and see if input comes up to 3.3v?
                              Lifted input leg of the 3.3V>1.7 regulator but input voltage remains at 2.5V..
                              • attainteddragon
                                • Apr 2013
                                • 764
                                • australia
                                so now start working your way back to the supply voltage. with a good working board it should be easier to do.
                                post a high res pic of the area if you want more help, though i can't view it for a bit. dam teenager ate all of the data and doesn't refresh for 5 days. :'(
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Here's pics.. I'll start looking at it tomorrow. If anyone can look for tips please and thanks
                                    I suspect that the output of 3.3V regulator is bad which it feeds the input of the 1.8V regulator IC.
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      I have 5v in and 3.3v out of that regulator.
                                        But some how it shows 2.5V at the input if the 1.8V regulator per your post:
                                        'Lifted input leg of the 3.3V>1.7 regulator but input voltage remains at 2.5V..'
                                        If you check the resistance between the 3.3V REG Output pin and the input pin of the 1.8V regulator, does it show < 1 Ohms?
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • thstuff
                                          Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                          by thstuff
                                          A) TV initially dead
                                          B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                          C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                          D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                          E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                          12-26-2024, 09:10 PM
                                        • jacobtc
                                          LG C1 65'' dead standby
                                          by jacobtc
                                          I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                                          If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                                          If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                                          I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                                          01-29-2025, 04:27 AM
                                        • mecha1166
                                          QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                          by mecha1166
                                          I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                          03-28-2024, 08:31 AM
