Toshiba 32D1333DB
  • Norman1
    • Jun 2017
    • 77
    • Uk
    Toshiba 32D1333DB
    Hello, have a dead Toshiba with a vestel 17IPS11 power board, replaced the 5 diodes, but no change. Anyone had anything extra go pop on the board?
  • heavymachines
    • Mar 2011
    • 1028
    Re: Toshiba 32D1333DB
    check more diodes and post pics please.
    • Norman1
      • Jun 2017
      • 77
      • Uk
      Pics
      • heavymachines
        • Mar 2011
        • 1028
        Pics of whole layout would be nice, and what is the exact symptoms?
        • heavymachines
          • Mar 2011
          • 1028
          Also is there any flashing led power light? brief flash of screen?
          • Norman1
            • Jun 2017
            • 77
            • Uk
            It's totally dead but I have just found the transistor next to the bank of diodes is s/c so il pop it out tomorrow to see if that's it il let you know how it go's
            • Norman1
              • Jun 2017
              • 77
              • Uk
              Well in case anyone wants an update, it was the main board causing it to be dead, so I changed it and now the s/by led is flashing red and green, somebody mentioned it might be the software as each board is slightly different, but there's no update available, unless somebody knows differently?
              • vinceroger69
                • Mar 2012
                • 6714
                post 57 in this thread may help you but im not sure how you upload it too these sets im sure a more experienced member will advise
                https://www.badcaps.net/forum/showth...D1333DB&page=3
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  It's a dump so the chip will need removing and an external programmer used.
                  • Norman1
                    • Jun 2017
                    • 77
                    • Uk
                    Sounds like it's heading for the recycling,,why is it that an exact replacement board isn't the same programming as the original one?
                    • Hamie
                      • Apr 2014
                      • 1383
                      Out of interest does it now turn on, ie backlight etc if you disconnect the wire to the TCON/panel?
                      If not your replacment board may be faulty?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        It would be worth doing the checks that Hamie suggests to see if you have a problem elsewhere. Are all the control signals doing what they should?
                        I'm sure someone had a similar problem with a set fitted with an integrated DVD player which when disconnected allowed the TV to power up.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          Maybe return the mainboard you got as it maybe faulty and look for another one that matches the lcd panel number as used in your tv ebay is a bit hit and miss with used boards lately were seeing a lot of faulty boards being sold has your replacement mainboard got a returns policy?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            You could try the following although it's for the 40" set
                            https://www.badcaps.net/forum/showthread.php?t=62962
                            • Norman1
                              • Jun 2017
                              • 77
                              • Uk
                              Hi guys, if i disconnect the t con panel its still the same fault,flashing red an green s/by light. is it worth trying a firmware update do you think? The numbers on my original main board are virtually identical to the replacement, and seeing as its gone from dead to a flashing s/by light maybe your right about a faulty board.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                i would take a back up of the old firmware on the board and save it then try the other firmware and see if it solves your issue
                                • Norman1
                                  • Jun 2017
                                  • 77
                                  • Uk
                                  Just to close the thread, the main board I replaced was giving me a slightly different fault, so i returned it and fitted another one with the exact numbers and hey presto fault cured whether or not the small string of numbers contributed to it or it was just a faulty board I don’t know. Thanks for all the help though, feel free to have a stab at the Panasonic I have on the listings, that one is a bugger
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    Thanks for the update glad you managed too fix the tv.
                                      09-06-2024, 05:27 AM
                                    • Dvsr
                                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                      by Dvsr
                                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                      After replacing the caps I started testing out the speaker. It seemed...
                                      09-10-2025, 10:20 AM
                                      09-06-2024, 05:59 AM
