Problem with Pana TX-P50UT30 - black screen
  • gldiana
    • Sep 2017
    • 16
    • Italy
    Dear all, my TX-P50UT30 randomly (sometimes after 15 min, sometimes after 90 min) gets black screen, no sound, and green led still on. OSD menus are ok...
    Can anyone help me to fix? Thank you!!
  • tw2005
    • Oct 2011
    • 6458
    Re: Problem with Pana TX-P50UT30 - black screen
    Sounds like a mainboard issue. Don't know how to fix it but maybe a BGA Chip is losing contact with heat.
    • gldiana
      • Sep 2017
      • 16
      • Italy
      Thank you very much for suggestion: I shall check and let you know!
      • dskall
        • Oct 2016
        • 2905
        • usa
        Does it do this on all inputs?
        • ducky29
          • Dec 2015
          • 370
          • Europe
          Try heating/cooling down the bga and see if that makes any difference.
          • gldiana
            • Sep 2017
            • 16
            • Italy
            Hi all'.
            Short update: the problem was on all inputs. So i changed A-board. problem solved.
            Thank you very much for your suggestions.
            • tw2005
              • Oct 2011
              • 6458
              Hi all'.
              You did not waste any time. Good job getting a board so quick. Usually by this age they're very hard to find.
              • VcemPzd
                Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                by VcemPzd
                Hello everyone !
                My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                04-28-2025, 10:14 AM
              • redwire
                Onkyo TX-SR607 HDMI problem showing a black screen intermittently
                by redwire
                Onkyo TX-SR607 HDMI problem showing a black screen intermittently, audio was OK.
                It would usually cut out a few minutes after power on, for maybe 1 minute then work OK, then cut out and go to black again. Or fade out to sparkles and noisy video.
                Well known is these boards need recapping and there is a strange mix of parts on both sides of the board.
                The bottom of the board has 100uF 4V (5.3*5.3mm, qty 5) and 220uF 4V (6.6*6.6mm, qty 5).
                Per the service bulletin, an issue is the Toshiba LDO's want low ESR for stability so I went with 100uF 6.3V polymer...
                11-16-2023, 08:56 PM
              • mmccomputer
                problem with replacing lcd screen
                by mmccomputer
                I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                If anyone has any information on the subject...
                12-15-2024, 03:44 PM
              • HTR-Informatique
                by HTR-Informatique
                02-09-2025, 06:51 AM
              • String2016
                Acer Predator PH315-52 no display/black screen problem - need working bios please.
                by String2016
                I need a working bios on this acer predator
                MODEL:ACER PREDATOR PH315-52 54KC
                S/N:NHQ54SP00A024028992600
                SNID:02401039326
                Attached is the original bios no display problem black screen keyboard lights on...
                10-10-2023, 06:00 PM
