Can't scan for channels on Vizio gallevia
  • Grandma
    • Sep 2017
    • 9
    • usa
    So I have an older Vizio Gallevia hdtv my daughter gave me in bedroom, and trying to hook it up to broadcast antenna. On the remote I can chose input then tv and I choose air. Then it takes me to Auto scan for channels. Then is only auto scans the analog channels. It just stops and never scans the digital channels. Ive tried resetting the tv from the remote. It doesn't matter. It always stops halfway. it scans analog then just sits there and stops before scanning for digital channel. There is no way to manual program them you can only auto scan.
  • CapLeaker
    Leaking Member
    • 8203
    Re: Can't scan for channels on Vizio gallevia
    Do a hard reset, factory default, rescan channels and report back.
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      look for dtv button on remote ..press it first
        What is the EXACT model number of the TV?
        • Grandma
          • Sep 2017
          • 9
          • usa
          Vizio gv42l fhdtv ---vizio gallevia Ive tried 2 different ways to factory reset. Holding down power button for 30 sec.when it was unplugged. And thru the remote. ive reset it. Nothing changes. and there is no dtvs button on remote. this was using antenna and broadcast channels for awhile then she moved it and it was on cable now ive moved it to bedroom and tried to put it back on antenna and it won't scan channels.
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            here is the manual .. it says it has dtv button .. can you get it into dtv mode ?
            http://tv.manualsonline.com/manuals/...v42l.html?p=27
            • CapLeaker
              Leaking Member
              • 8203
              is there maybe a firmware update you could do?
              • budwich
                • Jul 2015
                • 3097
                post a picture of the screen showing the menu that you are using to cause the scan... might help figure out where you are at versus where the forum is.
                further what is the surrounding "environment"... house / apartment / room.... how do you know that what the incoming cable is connected to... is it in a wall plate?
                • Grandma
                  • Sep 2017
                  • 9
                  • usa
                  I have manual. I have plugged it into the same connection it was plugged into before, the dtv/tv connection. There is no specific dtv button there is a tv button and a tv/dtv connection. The digital option is greyed out in the settings on menu which when I looked it up means it is not sensing anything is plugged in. I have to work all weekend but monday I should be able to buy another antenna and try it.
                  • Grandma
                    • Sep 2017
                    • 9
                    • usa
                    And THANKS! for everyone help so far! when I get another antenna on Monday I will post results.
                    • CapLeaker
                      Leaking Member
                      • 8203
                      You should be able to scan for digital channels with and without any antenna attached to the TV. You can't even get the thing to scan, so don't waste money on a new antenna.
                      • budwich
                        • Jul 2015
                        • 3097
                        I wasn't referring to the TV side of things... there is only one coax connector on the TV... I was talking about where the "other end" of the cable was plugged into... a wall plate, an outside cable, what? IF its the same "cable point" that your were plugged into before and said you were "taking cable tv service" and now you want to use "antenna" on the same connection... something has to change at the "far end" of the incoming cable connection. Basically, how about a picture of your tv antenna that you are trying to use.
                        • Grandma
                          • Sep 2017
                          • 9
                          • usa
                          Days off work again so I tried to fix tv Again it will not work.. I've used several indoor antenna's old and new. I took the mirror to help look in back to all connections. I'm connected to tv/dtv connection. if I take off the antenna the analog as well as the digital is greyed out so it is sensing the antenna. as you can see. from 2nd pic with antenna connected only the digital is greyed out.
                          [/URL][/IMG]
                          • maxvalutech
                            • 804
                            • australia
                            The manual has an anomaly in instructions. I would remove the antenna and turn set on for a few minutes then turn set off for a number of minutes including remove from pp. Then attach antenna plug set in and turn on. Then with remote push to select TV then push input and see if both options of TV and DTV show along with HDMI etc. If so select DTV and then go to scan menu.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              [/URL][/IMG]
                              are you sure thats the rite menu screen im sure digital cc means Closed Captioning that has nothing too do with the tuning of the tv
                              • budwich
                                • Jul 2015
                                • 3097
                                X2...ah ha... now we are getting some place.
                                from the picture... you need to be one more icon over for the antenna settings information.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  A further "ah ha". this has correctly identified the issue. You are currently selected as "TV" which means the in coming connection on the coax connector is expecting to see rf coming from things like a vcr or an "analog antenna signal". You need to press the "tv" button to select "DTV" instead of "TV" (the button has a dual "switching function" to switch the coax connection switch internal to the tv).
                                  • Grandma
                                    • Sep 2017
                                    • 9
                                    • usa
                                    Please excuse the bad pics. I'm in a hurry on my way to work. I have disconnected and reconnected power cord as well as antenna. to reset tv . It will not work. . also there is no tv/dtv button. there is tv/dtv connection. its the same exact connection! there is no tv/dtv/ button. there is tv if you push it , it does not change to dtv. that must be some other model. as you can see there is just 2 modes on tuner. air and cable. i was showing the other screen just so you could see digital is greyed out. When I try the auto scan it will only scan analog. it will never scan digital.
                                    [/URL][/IMG]
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      you have to push the tv button again... that cycles the connection between "tv" and "dtv".
                                      • Grandma
                                        • Sep 2017
                                        • 9
                                        • usa
                                        Theres no tv button that cycles between the 2. The tv, choice cycles to Tv/ then component1 then component 2 then RGB then hdmi 1 then hdmi 2. Ive tried it all. It is supposed to auto scan both analog and digital and it does not.
                                        • dicky96
                                          Hitachi V19B01922 Channel Tune problem
                                          by dicky96
                                          Hi Guys
                                          I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                                          He also has an LG TV, so three screens in the bar
                                          I installed three Satlink ST-6503 DVB-T Modulators
                                          This model https://www.aliexpress.com/item/32916553905.html
                                          These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                                          02-09-2023, 09:20 AM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
