Lg 47 led flashes then goes off
  • deegee2016
    • Apr 2016
    • 11
    • england
    I have an LG47ODUE that shows LG Logo then goes black under torchlight image is visible.
    Power supply board tests:
    Standby voltages: in order on connector:
    9) Ground - Ground = 0.0v
    8) 12v - NC = 11.95v
    7) 12v - 12v = 11.95v
    6) Ground - Ground = 0.0v
    5) 24v - 24v = 24.77v
    4) Ground - Ground = 0.0v
    3) 3.5v - PDIM2 = 3.54v
    2) 3.5v - PDIM1 = 3.55v
    1) PwrOn - DrvOn = 3.42v
    Most voltages not present until standby button is pressed
    Led Connector Tests:
    106v down to 82.2v at led connector on both lines. LEDs connected
    115v down to 82.2v at led connector on both lines. LEDs disconnected.
    Diode Side Test: (red probe to cathode side and black to test points at led connector)
    97v and decreases - cathode side of diode to test point at led connector.
    LEDs have been checked out of the unit on a DC power supply two strips at 30v all LEDs work.
    Work has been carried out previously as jumpers on led strips. Work fine out of unit on DCPS.
    I had image but no backlight.
    Could this be a caps issue???
    Does the TV need all LEDs connected to work correctly (ie) cut out if not enough LEDs for load.
    Obviously 88.2v is not enough to drive the leds
    Anjy help will be most welcome
    Regards Dee
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Lg 47 led flashes then goes off
    Can't find any reference to LG470DUE. Are you sure it's the correct model number. Do you have any photo's of the circuit boards.
    From the information provided it looks like you may well have led problems.
      82V is the feeding Voltage to the boost converter. We need good clear pictures of the whole back side of the TV showing all the boards and then good clear straight shot pictures of the top and the bottom side of the power supply board.
      How many LED strips are there and total Qty. of the LED's?
      LG47ODUE????
      "Work has been carried out previously as jumpers on led strips. Work fine out of unit on DCPS.
      Does the TV need all LEDs connected to work correctly (ie) cut out if not enough LEDs for load."
      What do you mean by jumpers on LED strips?
      • deegee2016
        • Apr 2016
        • 11
        • england
        Thanks for the reply.
        Its an LG 47" LED TV Panel model LC 470DUE(SFR-1)
        Links to photos below.
        https://ibb.co/eHwjuQ
        https://ibb.co/j0BZuQ
        https://ibb.co/dpMZuQ
        https://ibb.co/i9oEuQ
        https://ibb.co/eiWZuQ
        My led install:
        Previous repaired led install:
        • deegee2016
          • Apr 2016
          • 11
          • england
          Hi again lads will sort requested info and get it up for viewing .
          Led rows: 6 x two strips of 5 LEDs and 4 LEDs
          Backlight strip: 94v -1331 47" Row 2.1 (Rev 0.7) R1-Type 6916L-1174A
          Power supply: EAX64905501
          AV Board: EAX647970031(1.2)
          As stated there was previous work carried out which was not disclosed .
          I have replaced approx 8-10 LEDs and all strips work fine on DCPS.
          Also will only a few rows plugged in work or do they all need to be on for the load . ie too few and over voltage .
          Thanks dee
          • deegee2016
            • Apr 2016
            • 11
            • england
            Power Supply underside:
            https://ibb.co/bv1UeQ
            https://ibb.co/hoVpeQ
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Schematic for the power supply.
              http://electronicshelponline.blogspo...schematic.html
              You need all the leds connected and working for backlights to come on.
              If you are certain that all the leds are operating correctly then I would check the interconnections between led strips for continuity since this also tends to be a weak point.
              Leds suitable for the panel available from
              http://www.ebay.co.uk/itm/like/33200...1899735&crdt=0
              • deegee2016
                • Apr 2016
                • 11
                • england
                Thankyou Mr Barton for the link .
                So two or three only won't work it needs all connected and all LEDs functioning to stay illuminated.
                I don't have steady voltage at led connector it should stay at 94v or thereabouts but it decreases.
                Even with led connector pulled out .
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Panel spec for backlights state 99.9V +/- 8.1V operating
                  http://www.panelook.com/LC470DUE-SFR...ter_20159.html
                    '94V' printed on the strip is NOT the LED Voltage, that is the PCB compliance UL94V..
                      'Led rows: 6 x two strips of 5 LEDs and 4 LEDs'
                      So 6 x 9 = 54 LED's, since you have TWO LED driver circuits that means each circuits drives 54/2 = 27 LED'S x 3V = 81V forward Voltage per each string of the LED.
                      81V forward Voltage + Vdrops of the PWM controlled MOSFET + Vdrops on the current sensing resistor which means the Boosted Voltage should be a little over 100V.
                      This is what you need to do:
                      1) LED connector is in place.
                      2) TV is off
                      3) Keep the meter black probe of the chassis.
                      4) Red probe on the LED connector pin 1 (LED -) then turn on the TV and see how high the DC V goes up to and wait 5 seconds to see how low it goes to, report the reading, turn the TV OFF.
                      5) Red probe on the LED connector pin 3 (LED +) then turn on the TV and see how high the DC V goes up to and wait 5 seconds to see how low it goes to, report the reading, turn the TV OFF.
                      6) Red probe on the LED connector pin 5 (LED -) then turn on the TV and see how high the DC V goes up to and wait 5 seconds to see how low it goes to, report the reading, turn the TV OFF.
                      7) Red probe on the LED connector pin 7 (LED +) then turn on the TV and see how high the DC V goes up to and wait 5 seconds to see how low it goes to, report the reading, turn the TV OFF.
                      Similar board;
                      https://www.badcaps.net/forum/showthread.php?t=64503
                      • deegee2016
                        • Apr 2016
                        • 11
                        • england
                        Thankyou Budm for your help with this. I usually work on iphones so this is quite new to me at the moment.
                        I will get the voltage output readings for you in a bit and post with board image with results.
                        I have one strip that's been jumpered that I need to rectify first and all strips should be good before the test.
                        Once again thankyou
                        • deegee2016
                          • Apr 2016
                          • 11
                          • england
                          Well I'm back with readings.
                          I have repaired the backlights and they stay on now.
                          Voltages are as follows:
                          Red probe to pin 1 led + = 105v high / 99.6v low
                          Red probe to pin 3 led + = 106v high / 104.8v low
                          Red probe to pin 5 led - = 27.7v
                          Red probe to pin 7 led - = 29.9v
                          Problem I'm having now is all I can see is white spot glows no image .
                          I must admit I may have put the difusser sheets back to front , I have kept them in correct order can this cause this issue?
                          Thanks again for help.....
                            So what did you do to fix the backlights and make them staying on?
                            "Problem I'm having now is all I can see is white spot glows no image ." Please show us the screen shot of what you describe.
                            • deegee2016
                              • Apr 2016
                              • 11
                              • england
                              Thanks for replies, Well I replaced 35+ LEDs individually with my hot air station 10 secs at 280c airflow 40% .
                              I had the diffuser in front of the filters. I now have picture, sound with a little ghosting on 3 LEDs duevto lenses reflector spacers being removed on previous repair.
                              The picture is fine once the picture is on playing movie etc but when on menu you can see a few spots. Not cost effective to replace full array which is what I would have liked to do on this occasion.
                              Thanks again
                              • Pipolups
                                Corsair K70 LUX RGB dying LEDs
                                by Pipolups
                                Hi there !
                                I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                10-08-2024, 11:58 AM
                              • Bigfoot
                                Samsung TV UN60J6200AF No Display + No LED
                                by Bigfoot
                                Hi guys
                                I'm working on similar Samsung TV UN60J6200AF.
                                When I plug in power cord, the red light lights up, and flashes, then turns off.
                                I measured on the power supply board, and even without pressing the power on zbutton in getting on CNM803 (which goes from Power supply to Main board):
                                UD = 2.3V
                                PMW_BLU4 = 3.3V
                                PS_ON = 4.4V
                                A13V = 12.75V
                                I looked at the manual and all the voltages are correct.
                                When I unplug the main board from the power supply, LED lights are supposed to come on. However, non do come on.
                                06-20-2023, 10:24 PM
                              • odie34
                                Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                by odie34
                                I am a hobbyist (not a professional) so please be gentle...
                                I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                02-18-2024, 09:11 AM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • TrisHCl
                                LED TV Boot loop - UE40F6500SB
                                by TrisHCl
                                First post...
                                I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
                                Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
                                I disconnected the main board from the power...
                                02-06-2025, 08:42 AM
