samsung UE40EH6030WXXN not working
  • anno
    • Sep 2007
    • 140
    • netherlands
    i have a samsung UE40EH6030WXXN that is not working. led blinked 4 times.
    i changed the power supply BN44-00552A but still the tv is not working.
    the power led is blinking 4 times (if i`m correct)
    the ps-on signal is coming to 3.3v , the psu voltages are correct. But then the ps-on signal is going to 0v. When i disconnect the TCON cable from the mainboard the ps-on signal is staying stable at 3.3v . But nothing happens. no backlight or image.
    i tried to find a short on the TCON . I connect 12v external power supply to the fuse of tcon, but there is no short. it is taking 200ma.
    mainboard is bn41-01894a
    anyone can help?
  • paulstef
    • Dec 2013
    • 724
    Re: samsung UE40EH6030WXXN not working
    If you had an oscilloscope you could measure output voltage on the PSU LED connector. I had a few of these TVs with burnt LEDs.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Have you checked the Tcon fuse is OK and not open circuit?
      Edit
      Sorry, not open if current flowing. Have you checked any voltages on the Tcon board which may be marked eg VCC_1.2V, HVIN_12V, HAVDD, AVDD etc
      • anno
        • Sep 2007
        • 140
        • netherlands
        The Tcon fuse is ok. How to check the PSU LED connector. i have a scope.
        which pins i have to check?
        • dskall
          • Oct 2016
          • 2905
          • usa
          I would be checking for the various voltages on t-con
          • riogrande75
            • May 2010
            Hi!
            I know its quite a long time ago, but I just ask: Do you still have a close picture of the mainboard (BN41-01894A)? I need to know the type of IC 204 near the connector to the power supply board.
            Thx,
            Rio
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
            • nader_guesmi
              Samsung UE65TU7172 – BN41-02751C – CI+ ECP Keys Missing / Digi Card Not Working
              by nader_guesmi
              Hey everyone,
              I’m working on a Samsung UE65TU7172 with mainboard BN41-02751C. The TV powers on normally, I’ve applied the latest software update, and all measured voltages are correct.
              Problem: The CI+ module doesn’t read the Digi card.
              I accessed the service menu (using Mute + 2 + 4 + 7 + Exit) and ran the CI+ test. The results show:
              • CI+ production keys: Success
              • ECP keys: Not installed
              So the TV doesn’t even attempt to communicate with the CAM/card.
              I’ve tried multiple Digi cards (both old and new), and they work fine on another...
              09-09-2025, 03:04 PM
            • thesame
              Samsung UE40F6670SS messed tcon type in service mode.
              by thesame
              Hy guys i have this Samsung Tv model UE40F6670SS and i have messed with the service menu and selected the wrong tcon type .Is there a way to reset the service menu to defaults or how can i find the right tcon type since i didnt took a picture or remember the original setting?
              Since i have selected the wrong tcon type the colors are a bit strange and sometimes the backlight it looks like its auto adjusting... ...
              11-22-2023, 03:04 PM
            • triplefour
              Samsung UN55ES7003 has blown fuse on TCON and short to ground.
              by triplefour
              Samsung UN55ES7003
              made house call.
              red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
              psu has self test feature.
              disconnected from mainboard.
              determined PSU ok BL ok.
              suspect mainboard.
              disconnecting tcon has no change on operation.
              markings on mainboard:
              BN97-06531P 0151
              BN94-06123R
              found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
              for 54$
              second house call:
              with replacement mainboard, tv turns on, has sound,...
              07-13-2022, 03:53 PM
            • shelby5041
              Samsung LCD TV no picture backlight on no 12v at tcon
              by shelby5041
              hi
              i have a samsung lcd tv
              it powers on with sound and backlight but no picture
              all voltages from PS are good 12v 3.3v and 5v
              whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
              i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
              no 12v at the tcon fuse
              i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
              the odds of having 2...
              10-08-2021, 08:21 AM
