Re: Sony KDL40V4100-Dark Picture
I kind of doubt the "not getting 12v" "observation"... :-( It is unlikely that you would be getting any sort of picture if there was no power to the tcon.
further, checking voltage at a fuse isn't really how to check a fuse UNLESS you know exactly how the circuit is designed since some tv designs (and others) put fuses in places next to grounds which means a voltage measurement is going to yield "0".
You need to confirm 12v at areas where there are printings on circuit boards..... hence the OFTEN REPEAT quote here on this forum, provide good pictures of how the set boards are connected / laid out on the back off the set with clear ones showing printing of voltage / pin designations then people are able to readily move through appropriate questions / comments.
further, what is the history of the set? The "no sound on hdmi" could be as simple as a wrong setting although it is also possible the hdmi ports are toast since this is a common problem across sets.
