LG 47LX6500 T-Con or panel vertical Bars
  • microvibe
    • Mar 2013
    • 275
    • canada
    I have a 47 LX 6500. It has solid bars going vertical the mainboard seems to respond the two remote functions but menu or input doesn't change anything on the screen just stays the same. I do have audio. I can't find any info on repairing this t-con and it's a very expensive t-con I don't want to order it just to try it out. From the pictures does it look like panel or t-con. I'm pressing on the tab bonds changes nothing.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 47LX6500 T-Con or panel vertical Bars
    Looks like a bad Panel to me.
    • microvibe
      • Mar 2013
      • 275
      • canada
      That's to bad . Got it free would been nice tv for just a tcon.
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        sell it as art work!
        have you disconnected half of the t-con to see if you can get half of a good pic?
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • microvibe
          • Mar 2013
          • 275
          • canada
          I disconnected each side all I get is black and white alternates the sides I never get a video pick. That's why I thought it was the t con and not the panel
          • microvibe
            • Mar 2013
            • 275
            • canada
            Anyone else think it's the panel. When I disconnect one of the cables I forget which side I got half black half white none of the vertical bars and the other cable disconnected I think I had vertical bars on the side that should be showing the picture. Has anyone ever repaired one of these T cons it's a size of a mainboard has an LG XD chip on it they want over $100 on eBay for one
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              do the lines change position when you put the menu up, or change channel or volume?
              • microvibe
                • Mar 2013
                • 275
                • canada
                Yeah the bars do change it's not the same all the time price menu input Channel up and down excetera
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4458
                  • Italy - Milan
                  Microvibe please write well, it's already difficult for non english language people.. no commas, shortcuts etc.. try to find correct voltages on tcon, watch the dc-dc converters, follow some other threads.. search terms like avdd, vcom , vghc, vgl...
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Do you get a good menu on screen?
                    • Nick's Tvs
                      • Jan 2014
                      • 621
                      I would suggest you purchase the T-con board from a company that allows returns. If it doesn't work, at least you will know for sure, and you can always send it back minus what ever shipping fee and restoccking fee they charge. Generally 15% or 20% at most.
                      If you end up recycling the set, let me know, I would be interested in purchasing the main board from you.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4458
                        • Italy - Milan
                        Nick beware, i have a 46 led Philips that starts with good Philips logo, then garbled graphics and vertical bars and it stabilizes in a vertical bars pattern, i suspect cpu soldering since it have changes warm/cool, tomorrow i receive the new mainboard after a failed reflow (too much heat)..bye.
                        • microvibe
                          • Mar 2013
                          • 275
                          • canada
                          I don't get any normal picture no menu or nothing . Just vertical bars
                          • attainteddragon
                            • Apr 2013
                            • 764
                            • australia
                            i am leaning to t-con on this one, but i am no expert. this is where a scope would be very handy. check the input and output from the t-con.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4458
                              • Italy - Milan
                              mvibe the balls desoldering can be at a more advanced stage...
                              • Daren87
                                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                by Daren87
                                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                08-13-2023, 03:25 PM
                              • howardc64
                                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                by howardc64
                                Failure Symptom
                                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                Where is the short?
                                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                05-27-2025, 02:56 PM
                              • x_orange90_x
                                TCL 50S535 bad tcon or panel issue?
                                by x_orange90_x
                                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                03-29-2025, 11:02 PM
                              • advant
                                by advant
                                02-03-2020, 12:25 AM
                              • iglitare
                                by iglitare
                                09-04-2025, 07:13 AM
