Sharp LC70UQ17U won't power on - 3 long blinks, one short
  • dougdon
    • Sep 2017
    • 6
    Having some difficulties with my 70" Sharp TV purchased around 3 years ago. Model number is LC70UQ17U. Around a month ago the image on the tv occasionally started flickering pretty severely:
    https://www.youtube.com/watch?v=DXkY-qXxCNU
    If you restarted the TV the problem would go away. Around a week after it first started, however, the TV shut off while we were watching it and it won't turn back on. The front light blinks in the same pattern repeatedly -- three long blinks, pause, one short blink. Based on some research I did it sounded like it might be the power supply board, so I tried replacing it but it didn't work, still have the same blinking pattern. Then I thought the replacement part I had been shipped may have been defective, so I ordered another new one and it didn't work either.
    Someone pointed me to the service manual, and they found this:
    https://imgur.com/a/ln7y0
    Anyone knows how I'd go about fixing this, or if it's fixable? Thanks a lot
  • dougdon
    • Sep 2017
    • 6
    Re: Sharp LC70UQ17U won't power on - 3 long blinks, one short
    Here are the various boards in the TV
      A communication error on a Sharp set in most cases would indicate a main board fault. That is the first board in those pictures, the one with A/V inputs.
      • dougdon
        • Sep 2017
        • 6
        Thanks for the reply. So in your experience, if I replace the main board it should fix my problems?
          I have only fixed one before in another Sharp set, and it is possible there are other faults, but for a big 70" set I would have thought it is worth taking the chance. I have not looked up the cost of a main board, but you can usually find them for less than $100.
          I would say about 80% chance it is the main board at fault.
          • dougdon
            • Sep 2017
            • 6
            Thanks, I'll give it a shot. Appreciate the info
            • dougdon
              • Sep 2017
              • 6
              Well, unfortunately that didn't work... swapped out the main board today, plugged in, hit power and after around a minute the front light started blinking the same pattern as before. Is there any factory reset/ firmware I would need to update in order to get around this error code?
              Otherwise, any other ideas what might be causing the problem, and whether it can be fixed?
                Hmm, not sure unfortunately.
                Small chance the board you got is defective if purchased used/second hand (most boards are, rare to find genuinely new ones.)
                I guess there's a chance it's the T-con - 3rd picture in your first post - but I wouldn't think that as being very likely.
                You could try a second main board (consider an exchange with seller?), or a T-con, up to you, but I do not know, sorry.
                • budwich
                  • Jul 2015
                  • 3097
                  you can also try unplugging one cable going from tcon to panel and see what the result is. Repeat the test doing the same with other cable. Some form of stable picture may result (half that is still plugged in). Go from there. Ensure your cabling between boards is well connected / clean contacts.
                  • Superbee_dad
                    Sharp 80” long short flash backlight error - Help
                    by Superbee_dad
                    Hello Sharp TV experts
                    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                    01-24-2025, 11:51 PM
                  • Noobwithamultimeter
                    Sharp LC60C6400U - 2 long binks, 5 short blinks error code
                    by Noobwithamultimeter
                    Hi, long time browser - first time poster. I got my hands on a Sharp LC60C6400U and from what I could find on youtube similar models of this set have a 12V power regulator that fails called "KIA378R12PI". So I go ahead and order the part, install it and badda-bing my set worked right away. Only a problem - it failed after about 3 hours. So I re-attempted my solder joints and it was back in business, for a couple of days. Failed again with the same error code. I think to myself no worries I have 4 spares since I bought a 5 pack in case anything went wrong. But now after roasting the solder...
                    04-06-2021, 01:31 PM
                  • cm0002
                    Sharp LC-55N7000U 1 long 5 short blinking, no display
                    by cm0002
                    I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
                    Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
                    I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
                    06-19-2023, 06:21 PM
                  • Charrlie
                    Sharp Lc-70le734u blinking 2 long 5 short
                    by Charrlie
                    Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
                    So I busted into it and have done the following:
                    -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
                    07-07-2022, 02:02 PM
                  • Tom_x
                    HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
                    by Tom_x
                    I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
                    HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
                    Now with blinking capslock:
                    All voltage present on big coils, except +VCCGT (i don't know this need for booting)
                    I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
                    DDR4 ram is ok, tested on other laptop
                    WLAN and SSD removed,...
                    07-20-2023, 10:10 PM
