LF320EM5F weird picture
  • Sauktronics
    • Mar 2017
    I got this TV with a bad LED so I replaced the LED, and now this is what I get when i turn it on, any ideas? Its one of those tv's with everything on one board so PS,MB, & T-CON are all together. I was told the tv worked fine until the LED went out.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: LF320EM5F weird picture
    Looks like one of the cables from the board to the screen isn't fitted correctly.
    Or something got damaged on the little board that attaches to that half of the screen.
    Photos with the back off the TV off will help.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4688
      • Italy - Milan
      The problem is that center band has good colors while the rest is yellowish? Maybe you have 4 ribbons to the screen and 3 are not seated well or some small components on tcon flight away.
      • Asuma
        • Aug 2023
        • 6
        • San Luis Potosí
        I need the bin file please
        • Asuma
          • Aug 2023
          • 6
          • San Luis Potosí
          I need the bin file Eeprom, please
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • tvguy12012012120
            Picture degrades over ~2–3 minutes (washed out / low contrast) – panel vs T-CON/FRC vs main board diagnosis help
            by tvguy12012012120
            I’m troubleshooting a Westinghouse WD55UW4620 with a strange, very repeatable failure mode and I’m looking for insight on whether this points to the panel itself, T-CON/FRC board, or mainboard.
            Any ideas as to what would cause these symptoms?
            Symptoms:
            • From cold power-on, picture is perfect.
            • After ~2–3 minutes, the image slowly degrades:
              • contrast collapses
              • colors wash out / look incorrect (greens especially bad)
              • image looks “milky” / flat
            • Turning the TV off for a few minutes fully resets it; behavior repeats almost exactly each time.
            • Internal
            01-07-2026, 03:30 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • johnboy183
            LG Tcon board compatibility
            by johnboy183
            Getting no response from my earlier post on a Toshiba 49" TV failure which has now become clear is due to a physically damaged T Con board I thought it might be better to simplify by just asking on Tcon board compatibility.
            The physically damaged board is an LG 6871L- 4044D. I cant seem to locate the exact board anywhere but have been offered an LG 6871L-4044D board from a JVC 49" set . Does anyone see any obvious compatibility problems substituting this board for the existing?. The main components look identical but I assume there will be firmware differences.
            I am really...
            02-18-2026, 09:42 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
