Sony Bravia KDL-46NX800 Intermittant
  • bkelly
    • Aug 2017
    I have a TV that was connected to a circuit without protection. For some reason the garage in my '62 split shares some outlets in the main living room and the upstairs. I thought I had put a surge protector on it, but it turns out that that it was replaced with a simple strip.
    Error occurred when I was running a planer in the garage, hit some knotty wood and tripped the breaker.
    when I flipped the breaker back on, the TV started with a black screen that slowly shifted to white and there was some vertical magenta/red banding that could best be described as what looks like a stereo equalizer, as it warmed up the right half of the screen went completely white. Sound and menu buttons worked fine.
    I powered off for 10 min completely disconnected from wall, and after power cycling it went back to normal working picture. Since then its a crap shoot. Sometimes it works normally, sometimes the picture has the above described errors.
    I have not removed the back cover for any debugging yet as I don't really have a good debugging plan.
    The problem tends to be that the error condition only occurs when I have very little time to do any debugging early AM before work or late at night when I am ready for bed. A couple of power cycles or waiting with the main switch off for a few minutes most of the time brings it back.
    One time when it was malfunctioning a good downward whack on the top of the panel instantly fixed the issue.
    I have fairly good soldering station at work I could use and also I have access to a DVM and an Oscilliscope 100Khz and some good DC power sources if needed.
    Looking for help with plan of attack:
    1) check all DC voltages
    2) check caps for bulges/leakage
    3) Alternate connections of the TCON ribbon cables?
    4)????
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sony Bravia KDL-46NX800 Intermittant
    If a good whack at one time got it working again (percussive maintenance) then I would be tempted to open up the set and check all the boards for bad solder joints very carefully. Some solder joints may be fractured especially components attached to heatsinks due to repetitive heating/cooling cycles.
    • PopsCaps
      Sony Bravia KDL-40V2500 that will not power on
      by PopsCaps
      I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
      I do not hear any sound and I cannot see any backlight.
      I have tried disconnecting every cable on each board one at a time to see if anything changes.
      The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
      My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
      03-25-2025, 11:23 AM
    • justin35
      Sony bravia kdl-43w755c - boot loop
      by justin35
      i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
      from what i read online it looks to be an emmc issue…
      i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
      i took out the board and say an samsung 16gb emmc
      i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
      i could try to put one instead of the 16gb one, but will it work?
      where do i get the software from?
      any help will be much appreciated!...
      03-06-2024, 12:26 PM
      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
      10-16-2024, 05:15 AM
    • Spc.
      Sony Bravia KD43XF7596BAEP - Android no picture
      by Spc.
      Greetings everyone.
      I also have Sony Bravia, model:
      Sony Bravia KD43XF7596BAEP - Android.
      What happend is that image dissapeared while we were watching tv.
      Diagnostics:
      1. TV turns on, no errors
      2. Backlight turs on, no errors
      3. Power indicator turns on, white color, no errors
      4. Menu works on android, you can hear sound while switching channels
      5. Volume up and down works via TV remote and via buttons
      6. Tunner works, HEVC / MPEG-4 decoder works
      7. I get audio from channels
      8. No picture is present,...
      05-19-2022, 04:28 AM
    • KYBOSH
      Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
      by KYBOSH
      Previous owner said TV just went blank one day.
      They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
      Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
      The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
      There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
      I just downloaded the Sony KD-75X7800F Service Manual and...
      11-19-2024, 10:12 AM
