Panel is melting (SAMSUNG UE46D6510)
  • fluxflux
    • Mar 2017
    • 46
    • @MyCountry
    Dear Forum,
    My Samsung UE46D6510 has some horizontal bars/flickering and as I touched the bezel at the mid of right hand side it was very very hot (my fingers are almost burned).
    First I thougt there is something wrong with the LED Backlight but as I disassembled the Panel (LTJ460HW02-J) it shows that the panel melts.
    When power is applied, then the melted area begins to smoulder and to smoke.
    Question 1: Whats the Problem here?
    Question 2: Can this be fixed?
    Would be great if you could give me a hint.
    Kind regards
    FluxFlux
    Re: Panel is melting (SAMSUNG UE46D6510)
    1: It is a Samsung and the warranty is up so it is going into self destruct mode. Reality is probably a manufacturing defect leading to that driver IC failing destructively, although I've never seen one that bad! That certainly isn't normal. You may consider contacting Samsung about this as they may consider a good faith repair although I doubt it on a set this old (D series = 2011).
    2: No. Unfortunately not without a new panel. At which point you may as well buy a new TV. Perhaps don't buy a Samsung again. They aren't very well built compared to other manufacturers and rely on marketing a bit like Apple rather than producing a quality product.
    • fluxflux
      • Mar 2017
      • 46
      • @MyCountry
      Hi Tom66,
      thank you for your fast reply.
      Two more questions to get it correct:
      1: The IC form the TAB produces more current that the PCB circuit inside the panel is getting to hot and burning?
      Or
      2: There are additional "falut" mini-ICs inside the Panel (kind of sandwitch) ?
      Overall: For me it seems that this could lead to a real fire if I would have the set on and running while not in the room/house.
      Thank You.
      fluxflux
        1: There are components on that tab bond chip that are responsible for controlling the rows of the LCD panel. They select which line of the panel data is sent to at any given time. If the components go bad this could happen although it is really, really rare. Something must have gone badly wrong. It is probably drawing too much current from the T-con board causing the device to overheat. This would be almost certainly down to that chip on the tab bond, rather than any other part.
        2: There is an IC bonded to each tab, sometimes two, which control various functions, generally controlling rows or columns of the display panel. Some newer panel designs use "gate in panel" technology where the gate driver chip (that drives the rows) is embedded into the LCD glass. The function is more or less the same but the cost of producing the panel is less.
        Yes, this is a potential fire hazard so I would recommend reporting it to your local authorities and Samsung. While the plastic casing of the TV is usually made of flame retardant plastic, meaning it is unlikely that a fire would progress, it is still an unacceptable failure mode.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          There is a problem though , you opened up the tv and had the LCD out.
          I would do my best to put it all back together , dont damage any screws etc. If they only find 1 small scratch they might say you did it yourself......
          Hope you find a solution with Samsung.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4302
            • Italy - Milan
            What solution? Warranty is out... and if he detach that side tabs as in an other thread?
            Is possible a cleaning liquid spilling on the tab and making an overload?
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              There is no solution but replacing the panel. His tabbonding is melting deu to heat.
              Side tabs removal wont help. This is fault from the factory , not liquid. The tabs are on top of the tv not bottom
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4302
                • Italy - Milan
                "This is fault from the factory "
                2 years and more to show a defect?? strange.. when you clean screen liquid can go on the side, top or bottom, seen in many threads...
                  This is unlikely to be liquid damage as that tends to corrode. This is probably the silicon chip failing on the tab.
                  In any case, the high heat in that area has probably permanently damaged the liquid crystal matrix, so that is not usable any more.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4302
                    • Italy - Milan
                    i was thinking of a liquid that don't dried and at the power up have made a short, but may be is all water proof on the side..
                      Water rarely causes a short (DC resistance in 10~100kohm range.) Instead, it tends to lead to corrosion due to ion migration, which damages connections and reduces the effectiveness of insulation. Short circuits are very unlikely, although there is a small chance that water started a short circuit elsewhere in the circuit, causing this fault.
                      • Biruslapio
                        Samsung's AU series "high quality" panel internally melting
                        by Biruslapio
                        I got this 55 inch AU7X00 TV, it was rebooting and showed no image only a blink of the backlights.
                        I assumed it was either panel or motherboard. Turns out it was the panel, and after applying some tape on the ribbon cable that goes to the left side of the screen, the TV turned on with image, then I suddenly noticed a dark spot and the pixels were turning black on the left edge, I was sad and thought I smashed the screen somewhere, found nothing visually, it looked in perfect condition and if it was there before it would've been noticeable while I was inspecting the TV the first time....
                        07-12-2024, 10:08 AM
                      • howardc64
                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                        by howardc64
                        • Prior owner tried a replacement main board. No difference.
                        • Samsung 2x red blinking standby LED = panel fault
                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                        Yesterday, 10:54 PM
                        09-07-2024, 05:50 AM
                      • triplefour
                        SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                        by triplefour
                        TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                        tcon is built into mainboard.
                        Only one cable goes to panel boards.
                        there is a cable from one panel board to the other that links them.
                        cost cutting measure that results in us having harder time to diagnose.
                        removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                        used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                        07-28-2022, 07:59 PM
                      • NWArkGuy
                        Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                        by NWArkGuy
                        Well, I will be the first to admit that I screwed up...
                        In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                        I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                        I have 2 that I have found and have in my possession. ...
                        10-12-2023, 10:13 PM
