Philips 55PFL3907/F7 Dead, No Standby LED, Nothing, Please Help
  • sfernandes
    • Oct 2013
    • 229
    Re: Philips 55PFL3907/F7 Dead, No Standby LED, Nothing, Please Help
    Anyone know what I could check next?
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      #82
      Does the relay indeed close when you apply 5v to P-on ? I assume it does
      Wattevah...
      • sfernandes
        • Oct 2013
        • 229
        Yes I hear the relay make one click when power is applied.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          #84
          Is it possible to put together a list of the components you've already replaced, including capacitors ? I'm mostly interested in the small caps on the primary.
          Wattevah...
          • sfernandes
            • Oct 2013
            • 229
            Here is the list so far I have replaced...
            C1725, C1727, C1728 and C1402
            IC1201, IC1401 and IC1702
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              #86
              The rule of thumb when you're at wits' end and can't seem to get a power supply to turn on for the life of you is to replace every small cap on the primary...this is getting silly already Once you've got one going, the next time you get a similar supply with the same fault you'll know exactly where to look.
              Wattevah...
              • sfernandes
                • Oct 2013
                • 229
                The primary side of the power supply is the HOT side correct?
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  #88
                  Yes, where that main cap is located. The secondary is uninteresting at this point, since it appears to function normally, though I could be wrong....
                  Wattevah...
                    What DCV do you have on the PFC IC controller IC1401 (HPA00651DR/UCC28060) pin 2, 7, and 8 with ref. to primary circuit GND (negative leg of the main cap).
                    I suspect bad resistor networks R1425~1428_R1429, R1430~1433_R1407_1408, R1401~1404_R1405.
                    • sfernandes
                      • Oct 2013
                      • 229
                      Thanks for everyones help on this, but I have finally threw in the towel on this one and sourced a power supply and installed it and the set is working fine now. I did learn a lot though that will help me with other repairs and I thank you all for that. Cheers.
                      • alro7779
                        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                        by alro7779
                        Hello, guys!
                        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                        09-14-2025, 12:25 AM
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
                      • piposarcade
                        Samsung UN50KU6300 dead no standby led
                        by piposarcade
                        01-04-2024, 01:33 PM
                        Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                        05-22-2024, 02:07 PM
                      • fharris1977
                        Vizio D50u-D1 Dead Set No Standby
                        by fharris1977
                        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                        12-28-2023, 10:25 AM
                      • kew1701
                        Philips taw6205 ambilight speaker STM32 mcu dead
                        by kew1701
                        Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                        04-09-2025, 03:59 AM
