Toshiba 40L1333DB not turning on
  • smiddy1980
    HELLLLLP
    • Sep 2014
    • 57
    • Scotland
    Hello I have a Toshiba 40L1333db that wont power on, I am getting power going to the mainboard between 16v and 23v, when I unplug the main board it sits at a steady 23.2v is that an issue with the PSU or the Main board?
    Thanks guys
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Toshiba 40L1333DB not turning on
    Need good clear straight on pictures of back of tv with cover off and each board.
    • smiddy1980
      HELLLLLP
      • Sep 2014
      • 57
      • Scotland
      Sorry I meant to unload these
      • smiddy1980
        HELLLLLP
        • Sep 2014
        • 57
        • Scotland
        Do you think the main board can cause the power to voltage to go up and down like this or it is the PSU?
        • maxvalutech
          • 804
          • australia
          Is there a red standby light working if so there normally is a 5v line on PSU connector a ps-on or on to main board which if main OK then switches all other voltages on but also a backlight switch on etc. Lack of info gives a lack of response.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            +1
            It would help if you can give the dc voltages on CN4
            • smiddy1980
              HELLLLLP
              • Sep 2014
              • 57
              • Scotland
              Sorry for the lack of info guys, I'm not 100% sure of the layout of the pins but looking at CN4 on the board pin one being bottom left here is what I get the only voltage I get is pin 9 goes from 6 to 11v ping 12 13.2v that's with the main board disconnected
              • smiddy1980
                HELLLLLP
                • Sep 2014
                • 57
                • Scotland
                sorry pin 12 is 23.2v
                • maxvalutech
                  • 804
                  • australia
                  This is a LED set with the dreaded Vestel PSU. In my country we have all Chinese manufactured gear generally and no scarrt connectors so my comments are general. Your standby red light is going out at switch on and the power is coming on to a degree. Voltage fluctuations can be used as signals to turn on other circuits. At top of PSU what voltage is going from white connector to leds? For the other connector are pins identified on the board/s on top or underneath? Do you get sound? Does the set turn off OK as usual with remote or set button ? Any sign of screen lighting up at all even a flicker at switch on ? From answers to these and other questions the gurus can be confident in a diagnosis to assist in a fix. Most people look to board replacement as the solution but power supplies can sometimes be easily fixed. LED string problems are another matter.
                  • maxvalutech
                    • 804
                    • australia
                    Only just noted dick_barton has shown the pinouts. So your voltage readings raise question is you dmm reading correctly as a 5v movement would be likely at switch on for pin 9 but usually from near nil to 5. Also 23v instead of expected 12v is strange.
                    No voltage at backlight on so you need to isolate PSU from main and force it on to check what it does then force backlight on to see if LEDs respond. Dick will know which connections to make on this particular connector.
                    • zomi
                      • Nov 2011
                      • 505
                      What is the red light doing ?
                      flash green - red continoulsy..
                      goes green .. and nothign on scree
                      just stays red ?
                      • smiddy1980
                        HELLLLLP
                        • Sep 2014
                        • 57
                        • Scotland
                        Zomi, The light is red then green then off, its like the sets starts then shuts off and continues n this fashion
                        Maxvalutech I will check my meter to make sure I am on the correct setting, pretty sure I am
                        • smiddy1980
                          HELLLLLP
                          • Sep 2014
                          • 57
                          • Scotland
                          yeah my settings are ok, I can hear the board making a small clicking noise, like a switch going on /off very faint, with everything disconnected I'm am getting these voltages so I think it is the PSU that's at fault
                          • maxvalutech
                            • 804
                            • australia
                            I agree and the Vestel PSU hasn't many admirers on this forum as far as I can see. The relay clicking is normal as it switches. At switch on the 5v signal goes to main which reacts by voltage change back to PSU which then starts all other voltage outputs including sound and backlights the latter also usually controlled via main. Look to troubleshoot PSU by searching in forums or just replace with known good one if economical. Good luck with it.
                              09-06-2024, 05:59 AM
                              09-06-2024, 05:33 AM
                              Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                              This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                              09-06-2024, 05:30 AM
